Cars & Trucks Logo
Jason Patterson Posted on Aug 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which transmission is in my 94 chevy 2500 cheyenne truck the tranny that came out has 3 plugs and the new one i found hasd5 and also the vin calls year model 94 when the manufacture date is 08/94 whic
Which transmission is in my 94 chevy 2500 cheyenne truck with 5.0 in it.. The tranny that came out has 3 plugs and the new one i found hasd5 and also the vin calls year model 94 when the manufacture date is 08/94 which i thought was a 95 year model
bsheep
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 189 Answers
  • Posted on Aug 31, 2014
bsheep
Expert
Level 2:
New Friend:
Cheetah:
Answers
189
Questions
Helped
31749
Points
358
It still should interchange check clearance on firewall and bolt pattern make sure torque convertor goes on smooth also
  • Jason Patterson
    Jason Patterson Aug 31, 2014
    yeah but not sure if it is the 4l60e or the 4l80e that came in it and what about the computer and wiring diffrence
1helpful
I have a 2002 gmc envoy trans went out will a 2001 chevy silverado work if not what will thanks
no ENGINE TOLD AT ALL, SOME NEED HIGHER TORQUE TRANNY
THIS CAR HAS RPO , LIST BASED ON VIN AND TELLS THE 3 DIGIT COLD FOR TRANNY , ALL GM DEALER CAN LOOK UP THAT CODE
must fit and not make the TCM angry.
ask chevy maker for the fits list
or ask any transmission repair shops for the list.
a transmission, has many options by class series number.
even different RATIO'S AND LENGTH, MOUNTS AND TCM CONNECTIONS FUNCTIONS.
EXAMPLES ,NOT SAYING IT IS YOURS, ONLY CAN BE.
SERIES 4L60E (JUST A SERIES ok , UNDER STAND ?)
M30 : TRANSMISSION, AUTO 4 SPD, HMD, 4L60E, ELECTRONIC
NO ENGINE TOLD
NO VIN TOLD SO I CAN GET THE RPO LIST ,BEST IS YOU TELL GM THE VIN AND YOU GET THE RPO.
RPO, IS THE AS BUILT LIST.
THEN SHOP. BY RPO(TRANS) CODE.
1helpful
2answers
Are there freeze plugs behind tranny on a 94 4.3 chevy engine
Gene, there are freeze plugs on the engine in which transmission would have to be removed to access. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Replace Freeze Plug On GM 4 3 V6 Engine
Block Plug Basics Tech Article Chevy High Performance Magazine
4 3L Freeze Plug Locations Blazer Forum Chevy Blazer Forums
What transmission do i have in my 94 chevy 2500 cheyenne ?
There should be a tag on the tranny to tell you, might have to look a little but you will find it.
Check tranny fluid on manual1992 chevy cheyenne
There is a plug on the side of the transmission with a square hole in it (3/8 inch) passenger side usually. Remove it, if fluid doesn't come out of it, ad some until it does. It is full then. Auto parts stores will tell you the grade you need. If it's been a really long time. On the bottom there is a same plug. Drain it and fill.
2answers
Can a 94 chevy cheyenne transmission interchange with a 97 chevy silverado tranmission
Will it physically fit? yes. Will it be a direct replacement any everything hook right up and plug right in? If we are talking about an automatic then no. 1994's wiring was completely different than the 1997. Can it be made to work? possible, but I believe it would be more trouble trying to make it work than if the correct transmission were located and installed. If it is a cost issue where he has a good trans out of a 1994 he might see if a salvage yard will do some partial trading for the correct trans.
1994 chevy 2500 spark plug wiring
1994 Chevrolet C 1500 P/U 2WD 4.3 liter V-6 VIN "Z"
1994 Chevrolet C 1500 P/U 2WD 5.0 liter V-8 VIN "H"
1994 Chevrolet C 1500 P/U 2WD 5.7 liter V-8 VIN "K"
Hope ths help (remember comment and rated this).
My 94 chevy is leaking tranny fluid from the line to the radiator
What are you asking hear, if you know wear its leaking then you have to bite the bullet and fix it, there is no easy way, the only other way is you have to take the cross member out and drop the tranny down to get a clear shot at it its up to you.
22helpful
3answers
Distributor cap firing order 1993 chevy cheyenne truck v6
Firing order is 1-6-5-4-3-2 cyls. # 1-3-5 on drivers side front to back and cyls. # 2-4-6 passenger side front to back.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
