Question about RIM BlackBerry Pearl 8120 Cellular Phone
Blackberry 8320 Camera not working
I have a Blackberry 8320 Curve the camera worked and all of a sudden it stopped working. Phone was not dropped, did not get wet, or mistreated in anyway. I have tried hard resets, reinstalled my software back to 4.5 OS, cleared the cookies, cleared tasks, closed out out of any applications that I could, but nothing works. I could take it to a T-Mobile store but A. It's out of warranty and 2. I don't think it is a hardware issue because it was working before and I haven't done anything to change the camera settings or abused the phone. Can you help? Thanks
  • Vincent_G
    Vincent_G May 11, 2010
    This is the initial sign of the camera coming loose from the socket on the main board.
    If it still in warranty then send it out for repair.
    If it's out of the warranty then you can put a foam or plastic spacer to under the battery cover.
    Just like the battery foam pad under the battery cord to give it firm support.
    Place few tab of supporting material under the battery cover. Make sure they does not cover the lense or the flash.
    Next
    time the camera give you the error message again or ghost like image.
    Take the battery
    out and press the camera and flash area firmly until you hear a soft
    plastic snap sound.
    YOU MAKE HAVE TO DO THIS MANY TIMES
    Once the camera contacts snap back in place then your are back in business.
4 Suggested Answers
fleshgear
  • 541 Answers
SOURCE: My Blackberry Curve 8320 does NOT have Blackberry Messenger
If you want to install Blackberry Messenger on handheld do the following steps :
  1. Download the latest BlackBerry Device Software from your service provider's web site.
  2. Install the BlackBerry Device Software onto a computer that has BlackBerry Desktop Manager installed on it.
  3. Connect your BlackBerry device to the computer.
  4. From BlackBerry Desktop Manager, double-click Application Loader and follow the instructions in the Application Loader Wizard to install the BlackBerry Messenger application.
Posted on May 27, 2009
  • 50 Answers
SOURCE: Keys Not Working after Water
there is an area under the track ball that goes bad if it get's wet. Cleaning that area with a brush can sometime get it up and running again. If you're out of warranty try to remove the trackball and clean the area below it if necessary. There is a Blackberry Repair Guide that shows how to open a Blackberry and remove the track ball yourself.
Posted on Jun 17, 2009
polishgiant
  • 14 Answers
SOURCE: blackberry curve 8320 wont charge? Keep sayin
Have you tried different chargers?
It's either the voltage regulator in your curve or a very weak almost dead battery.
You can test the batt if you have a friend with a curve, swap batteries in your phones and if yours works again and his does what yours did, get a new battery and all is well. If yours keeps acting up with the swapped battery, it may be time to get a new phone.
Posted on Jun 25, 2009
How do I find MEP code for my blackberry curve 8320
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.
Get this Blackberry curve 8320 Imei Unlock Code .i hope this will help you :)
Good Luck.
Nov 25, 2011 | AT&T Blackberry Curve 8300 Smartphone
My curve is locked in camera mode. My daughter presses "something" and I cant get out of camera or snap a picture to get out of camera or go back to home screen. power down didnt help - help!!
Reflash your blackberry phone, it should be works and will make your blackberry camera curve 8300 unlocked. If that solution not working, bring your phone to nearest mobile phone repair shop and asking them to unlock blackberry using cable unlock. It's not only unlock your camera but also unlock your network if successful.
Mar 06, 2011 | AT&T Blackberry Curve 8300 Smartphone
Camera and Video Recorder does not work
you need to reflash you OS on to the phone...
you can connect the phone using the usb cable to the laptop/pc/mac that you are using then open your desktop manager (blackberry).....open apploader then click on software update and upload the OS back to the phone this should work...it has for every phone
Jul 26, 2009 | RIM Blackberry Curve 8300
Blackberry curve 8320 camera
Take the battery cover off. Take your finger and press on the lens area (below the flash) you should hear a "snap". Don;t over do it though.
Jul 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
BB Curve camera won't funtion
Just like the battery foam pad under the battery.
Next time the camera give you the error message again. Take the battery out and press the camera and flash area firmly until you hear a soft plastic snap sound.
Once the camera contacts snap back in placet then your are back in business.
Jul 07, 2009 | RIM Blackberry Curve 8300
App error 523
On the BlackBerry smartphone, the following error message appears after pressing the mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Please proceed to open and run the Application Loader.
Jun 29, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My camera freezes up my phone when i try to open it on blackberry 8320
This is a camera chip module problem OR camera software problem. First, try to reset your phone to factory defaults. If that doesn't help, have your phone's ROM reflashed. If that doesn't help. Your phone's camera chip is probably busted. You can have it fixed, not cheap though... if your phone is still under warranty, better phone your carrier or blackberry for warranty claim
Jun 14, 2009 | RIM Blackberry Curve 8300
Need mep code to unlock
you can Unlock your Blackberry 8320 Curve with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry. get your Blackberry 8320 Curve Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Apr 03, 2009 | AT&T Blackberry Curve 8300 Smartphone
My camera on my blackberry curve is not working. ]
I found this solution on Blackberry forums. You'll need to take the battery cover off, and then push on the camera lens, or more accurately, the ring surrounding the camera lens. You should see the image corrected. I just tried it on mine, and it worked like a charm. Easy, cheap, quick fix.
I'd be curious to know if it's an electrical problem, a lighting problem (most likely) or a physical lens issue (focus).
Anyway, try it - it should work.
Dec 09, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Pearl 8120 Cellular Phone Logo
662 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
