Question about Samsung Computers & Internet
Samsung 2294 Resolution problem
I have a Samsung 2294 Wide Flat Panel with full HD. I have connected it to my 9600GT Nvidia with a HDMI cable through a DVI adapter, but I am getting loads of problems setting my resolution to anywhere near 1920x1080p, any reason why? Only thing I can think of is that it is throught the adapter
  • flik776 Jul 02, 2009
    I downloaded the latest Nvidia drivers and only one driver is available for the monitor. Both are installed. Is it something that can be averted, I have had the monitor running correctly but believe it or not the computer decides when and how it does this. I only switch the monitor off for a while to come back and find it at a lower res which I can then change to the proper, high res and it works. Sounds weird but true!
  • 22 Answers
According to the manufacturer's website, the card is capable of more than that. Did you install the latest drivers for the monitor and the video card? If so, I would suggest that yes, the adapter might be the problem. I could not find any reference to the Samsung 2294 WFP on any website, and am unfamiliar with that model, so I don't know what the capabilities of that machine are.
Posted on Jul 02, 2009
Struggling to connect my Goodmans Freeview+ HD recorder (HDMI output) to either the DVI (female) or VGA (female) input of my Samsung LE27T61B TV which is HD ready with a resolution of 1366 x 768.
They are different protocols. You have to have a converter than changes the protocol (protocol is like a language...it needs to be translated to a different language). They are available from eBay or amazon but they don't always work very well. Best thing to do is get a unit with the correct connections.
Jul 14, 2016 | Samsung Televison & Video
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
I can't get a signal between my Sony Blu-Ray Disc/DVD Player and Samsung HDTV monitor. They are connected via a HDMI cable. A brief message on the HDTV reads "Not supported".
First, try to reset resolution of HDMI Sony BD output.
Unplug HDMI cable from TV and change to Component connection to reset BD output resolution.
Than after you entered to resolution menu, choose to standart resolution 720 or 480 i.
If above methode working, try to reconect HDMI cable again to HD TV.
If any problem with picture or still "Not Supported" messege appear, i suggest to change HDMI cable first.
i hope its work.
Mar 14, 2011 | Televison & Video
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I AM FROM INDIA I RECENTLY PURCHASED AN AIRTEL DTH HD VERSION, SINCE I HAVE A SAMSUNG LCD MONITOR (SYNCMASTER 2233sw) WHICH SUPPORTS FULL HD (1920X1080). MY MONITOR RUNS FULL HD WITH DVI CABLES OF...
Hi gurmeet,
What I suspected from your description of problem is that there is some kind of compatibility issue or content protection when you plug in an additional HDMI to DVI converter.
I am also using an Airtel HD connection, though however, I wouldn't need any kind of converter because I am directly connecting HDMI cable to my LCD and it works like a wonder. I set up my box output resolution to 1080i and there is no display resolution mismatch. Not even at other resolutions.
Airtel is using 1920x1080 resolution in signal transmission, so the possibility of 1079 from there end is ruled out, otherwise, the same problem would have been observed when direct HDMI cable is being used. I hope you understand my point.
Now you might also ask why you weren't able to see this problem when you connect the monitor to your PC graphics card. I would like to tell you that graphic cards are very versatile and does have the capability of 1:1 pixel mapping, so there you wouldn't see any such problem.
read this link for more http://www.hdtvsupply.com/hdtodvico.html , where a person is able to match resolution using a similar converter.
I believe the converter you use isn't able to do 1:1 pixel mapping and is actually downgrading the resolution which your monitor is not able to support.
You can try out other resolution type from the STB and if you still see similar problems, then you may need to get an alternative converter.
Follow these steps to change the STB resolution type;
Enter the Menu from STB remote -> scroll to 'My Settings' -> Enter 'System Setup' -> 'HD Setup'. Here you change to a lower resolution and press ok from remote.
Sep 22, 2010 | Samsung Televison & Video
What is the optimal cable type to connect the Samsung UN55B8500 to a DirecTV HD tuner? Are there specific TV settings to use for this cable type
The best cable hook up to use is the just the one HDMI cable. Just hook it up from box to TV and change the input selection on your TV to HDMI. Then on the Directv Box, change the resolution to 1080 for the best image.
Nov 09, 2009 | Samsung UN55B8000 55 in. LCD HDTV
I have a samsung lcd tv and am trying to connect my lap top through an hdmi lead. The tv shows an error that there is no signal. I have followed the instructions shown in the tv manual and have changed the...
Does your notebook have HDMI or DVI outputs? If no, then use standard VGA cable, which is supported by this TV and quality is fine also on 1920x1080 resolution. Also for VGA input on TV you can use almost any resolution the notebook supports (for HDMI only few resolutions are supported).
Oct 05, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Computers & Internet Logo
273 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
