Question about Kenmore 23012 Top Load Washer
Kenmore model # 110.22632.100 does not spin real fast inspin cycl
Clothes on top seem to be drier the ones on the bottom are wetter and need to be spun again
  • kwdavis Jul 02, 2009
    It is not a dryer it is a washer kenmore direct drive and it is in he spin mode I have the problem
    Problem Solver:
  • 9 Answers
Turn dryer on & make sure that the drum on your dryer is spinning, this could be a belt issue going bad or if the drum is not spinning the belt has broke. It also could be the lint system needs to pulled appart and cleaned out with a chop vac. It could also be exhaust tube kinked behind the machine.
Posted on Jul 02, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore washer top load all cycles normal but when in the rinse/spin cycle notice it does not seem to spin fast enough to remove water from clothes and the are wetter then normal
There could be a number of reasons My best guess is that it will reduce the spin speed if it thinks it can't drain properly. Check that all the pipes/ filters etc are clear and that it can drain all the water out. Also it wont spin fast if the load is unbalanced. Does the spin speed change according to loading or is it low all the time? It may have a motor control problem, but that seems unlikely if it's working normally other than the spin.
Jan 13, 2011 | Washing Machines
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
Occasionally won't spin and when it does it is not at full force
You need the coupling replace between the motor and the transmission.  It's a $20 part.
Mar 12, 2009 | Kenmore 46462 Front Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Washing machine spinning cycle
Either the balance sensor is stopping full RPMs - or the motor controller board itself.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Kenmore Elite 21086
sounds like a bad clutch also check the lid switch and make sure it is not intermittent
Jan 16, 2009 | Kenmore Elite HE4 Electric Dryer
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Kenmore 23012 Top Load Washer Logo
137 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
