I've also changed the battery and alternator my battery hand goes up to almost 16 sometimes and the lights be flickering
You don`t say what year and model this is. if you have a system charging at 16 volts, then you know its over charging. are you checking this with a volt meter independent of the car as the meter in the dash maybe wrong. if its over charging with an independent gage it could be the computer as it controls the ground circuit to cause the system to charge and discharge to keep the charging rate within specs. the flickering is a result of the over charging.
SOURCE: flickering lights
In some 1999/2000 Cougars the wire between the battery and the voltage regulator(altenator) had a resistance reading that is too high. Ford has issued an TSB 00-25-6 that has instructions on how to replace this wire. The part # for the replacement wire is
1S8Z-14A411-AA. I'm in Michigan and a local dealer found one for me in South Bend,IN
