Question about Mitsubishi WS-55807 TV
<!-- from fixya rte -->Why does my tv go off frequently? - Mitsubishi WS-55807 TV
    Top Expert:
  • Mitsubishi Master
  • 76,060 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Aug 31, 2014
SOURCE:
Tv keeps turning off and remote power button does not work
If the TV keeps On/Off frequently, and do not switch On, there is some fault with its its internal circuit. It sill be best to contact any technician in this mater.
Sep 23, 2013 | Philips 32PT6441/37 32" TV
Sound distortion on lcd tv
If you mean by this that their is an occassional echo, then this is a frequent problem with digital reception and not a fault with your TV. This is a wide spread problem that doesn't appear to have a solution
Feb 15, 2013 | Digihome LCD TV
I have a 50" philips magnavox tv that changes channels on it own and turns itself on frequently. What is causing this issue?
Do you live with someone who likes practical jokes; even silly ones?
There are a number of companies that make remotes that can mess with someones TV or other remote devices.
I have a watch, as a gag, that will self program its remote to operate any TV capable of this feature. With this watch, I can change channels, power status and even reset the TV to factory default state.
Next time this happens, look behind you.
Jan 15, 2013 | Televison & Video
How do I child lock my Sony Wega Tv?
Click here to download the user manual to your TV. It has all details.
Aug 02, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sharp Aquos LC-C4654U The TV blacks out frequently. The blackouts last aprox. 1-2 sec and when the picture reappears, the blue box appears in the top right corner (just like when the tv is initially...
Good day!!! That problem is cause of faulty capacitors on the power supply... just look at the actual image of it through visual check if the capacitors look like leak/bulged on top you need to replace it to end that problem... hope it helps... \thanks for using fixya..
Sep 13, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
The tv is plugged in but doesn't play
First off all, check your TV fuse for blown. The totally dead TV frequently cause by simple thing, the 'Fuse'.
Jun 22, 2011 | Protron PLTV3250 32 in. LCD Television
Bush tv frequently turning itself off
make sure you have not accidentaly scheduled a power off and on if yes torn off/disable them if not check that your power cable is secure
Dec 21, 2009 | Televison & Video
Sound cuts out frequently for a few seconds
Its possible this could be resolve without taking the tv back. Make sure it's not the source. IE cable box, xbox or ps3 etc. Try swapping out wires. If all else fails, then one board should be the culprit. I believe (If my memory serves me correctly) the name of the board in the A-board. The input board. If its under warranty, then you may want to call for service.
May 26, 2009 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Plasma Tvs
When switching to STBY raster remains and buzz noise is heared from the speakers
Cause: +B voltage (103 V) does not switch-off. Remedy: Replace defective C541
Ticking noise and line in picture
Transistor 7381 (BC848C) defective when hot
Dead with ticking noise from line
Replaced C622, C604 and Q509
Nov 26, 2007 | Televison & Video
Mitsubishi WS-55807 TV Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
