I have a pioneer purevision pdp-504pu 50" plasma hd tv and im getting green pixels mostly towards the middle and bottom of the screen i was searching on the internet and maybe found the solution i guess there supposed to be a little knob called "vscan" that you either turn clockwise or counterclockwise and it should remove those green pixels the problem is when i take the back panel off the tv is that going to trigger a white switch like the media reciever also has built in and if it does how do i reset it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: My PIONEER PDP-503HDE 50 INCH PLASMA screen won't power up
you guessed right you got a problem with the projector, I always point my finger to Power suppy problems on these sets for about any other problem would mean throw-away or too expensize to fix. good luck
SOURCE: Upgrading media receiver on Pioneer PlasmaPDP-5030HD
You can use a
PDPR06U
if you can find one for sale its 2 generations later than your's. Look on Ebay. I might have one too but I got to look.
SOURCE: where can I sell a pioneer pdp 5070pu plasma tv for parts?
HI, the best way to do this is to disassemble the set and post all the individual internal parts like the power board and main PCB logic and v boards, on line on a e-bay type of sale forum. this way, you can make more money. if you post the entire plasma screen with the crack as is, you will not get many hits. is will be assumed that it is damage goods.
Breaking this set down and, posting the internal circuitry piece by piece will make you more money in this case. The power supply board will sale for at least 289.00. and the main logic(PCB) will sale for 300 to 350. i would go this route to maximizes your gain.
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the top left
corner of the display window. It will
make search easy. Some times, the ads
attached with each posts, both at the right and bottom, might help you to find
the availability of spare parts. There
are more than 800 posts to different brand TVs now.
