Question about ViewSonic A70f 17" CRT Monitor
Screen flashes and sides squeeze in and out
Monitor screen flashes rapidly and sides squeeze in and out
    President:
  • 4,070 Answers
You need to replace your monitor. it trips when it gets old, its inevitable
Posted on Jul 02, 2009
  • ViewSonic Master
  • 19,396 Answers
If this is a CRT, then the horizontal deflection circuit is faulty.
The repair is generally not worth on CRT.
First try leaving monitor power cord unplugged for few hours, to discharge capacitors, sometimes this can fix minor problems.
Test also the display on different computers, you never know that this depends from a faulty video adapter.
More likely you will need to replace the screen.
Locate and replace the turn signal flasher relay in my 2012 Nissan Rogue....Fix rapid flashing for right turn
Rapid flashing on one side indicates a burned out bulb on the side that flashes rapidly. Check for a bad bulb.
Mar 31, 2018 | Nissan Cars & Trucks
Touch screen wont turn on power light keeps flashing green, rapidly, worked right up till we moved it to a new computer. what do i do?
It may be that the cord you have plugged into the tower either a.) doesn't like the plug in or b.) your going to need to adjust power and voltage settings to the monitor
Oct 30, 2010 | Elotouch 17" LCD Monitor
Screen Shakes on High Resolutions
your rate of refresh is too high, it's refreshing too fast, you need to lower the screen resolution. keep in mind, the tv resolution is much much smaller than a computer monitor. a computer monitor has much higher resolution. so Tv can only handle so much in resolution. if you need a better picture, it always the best to buy a monitor, not a tv for computer to get a good picture. if you have any more questions, let me know.
Oct 17, 2009 | Televison & Video
Pink color
check the led back light of your monitor. I you cant do-it-yourself better to go to service center
Jul 30, 2009 | Samsung SyncMaster 920NW Monitor
Toshiba TE2100, Sreen flashes rapidly on and off, If I tap it on the side, it stops flashing, bu intermitently starts again. Seems lide aloose connection in the wiring to screen, as computer will still...
Sounds like you are correct about the loose connection. There is a thin ribbon cable that powers the monitor.
You will have to download instructions for taking your laptop apart, but once you do, simply reseat the ribbon cable. That should fix it! Good Luck.
Apr 07, 2009 | Toshiba TE2100 Notebook
HP Pavillion vf15 Monitor flashes off and on rapidly
sounds like the cable is out but i dont know how to fix it srry
Mar 26, 2009 | Computers & Internet
Rapid shuddering of icons, pix on Acer X193W monitor (10 mo. old)
in very first you have to check the pc with another display monitor
if display problem still available check the graphic card and video driver. remove the driver and reboot. check display resolution and refresh rate
Apr 12, 2017 | Acer X193W LCD Monitor
HP Pavilion 17" screen flashes on and off
Try reinstalling your monitor. You should have a disc that came with all of your equipment.Make sure it is a clean install and there are no other programs running. Also check all connections to make sure they are tight.
If this does not help, do you have another monitor you can install temporarily so that you can work on this problem?
Is this a new monitor installation? You might want to check your hardware compatibility list which you will find under Start>Programs>accessories>compatibility wizard.
Aug 21, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor flickers and image is reduced and squeezed
Heat related dry solder issue Horizontal output side.
Apr 02, 2007 | HP Compaq FS7600 17" CRT Monitor
ViewSonic A70f 17" CRT Monitor Logo
69 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
