Question about Westinghouse DPF-0702 Digital Picture Frame, Digital Photo Viewer
I have a DPF-1411. It will run thru one cycle and then freeze on last picture. Turn off-on and does same thing.
  • izzy_nixon
    izzy_nixon Apr 20, 2012
    did you solve it mines doing same?
  • 999 Answers
There should be a repeat setting in the menu. It is only playing once through and stopping.
Eric
Posted on Jul 02, 2009
My DPF-1411 has stopped working, wont power on at all. I have tried plugging it into various plugs and holding down the power button but nothing happens. What else can I d?
do this steps:
1. check the power supply adaptor cord ,stranded wires inside sometimes breaks without your knowing.
2. Use a voltmeter to check the voltage output from the adaptor if doesnt react and no reading at all replace it .
3. if the powersupply is good, open the back cover and find the fuseable resistor inside the power source section of the board. replace it with the same value and put it back the cover and you are good to go. thanks
Dec 04, 2016 | Computers & Internet
Pictures not showing.
make sure the cards' slide button is in the unlock position..then check to see which size cards the frame can work with..mb sizes like 2/4/6/8/12 etc..
Jan 11, 2014 | Audiovox DPF700 Digital Picture Frame
Fim200a does not make the cubes large enough
If you just started having this problem now and it was making the right size ice before then i would first look at cleaning the ice machine including the condenser coil. second thing make sure that the water inlet valve is not seeping water by when it is in freeze mode just a little warmer water will cause it to not make good ice and a longer freeze time. last thing would be to adjust the I.S.Adjust: Ice size adjustment on the control board. Turn screw clockwise, and the size of individual ice cubes will be larger in the next cycle; the cycle time will be longer. Turn the screw counter-clockwise, and the ice will be smaller in the next cycle. only do this if every thing ealse checks out good.
Dec 05, 2013 | Franklin Industries Franklin Chef FIM200...
WE ARE CURRENTLY IN NORTHERN TERRITORY VERY HOT AND HUMID. RUNNING AC THRU THE NIGHT IT STOPS BLOWING COLD AIR AND FAN SEEMS TO BE NOISY. HAS IT ICED UP DUE TO THE HUMIDITY. UNIT BEING RUN THRU THE DAY NO...
If your coil is freezing at night, it sounds like your getting cold enough at night to have your saturation temperature drop below the design of what the AC is able to do. If it runs all day without an issue and freezes up at night, you need to add what is called an outdoor fan cycling switch. This will turn the condenser fan off when the saturation temperature drops so it will not freeze your coil at night. You need to have an HVAC technician install this. It is not a DIY projuect since it has adjustments that need to be right. Plus, it it's a heat pump, it needs to drop the switch off in the winter.
Sep 28, 2010 | Heating & Cooling
Westinghouse dpf 1411 shuts off after 2 minutes, wont stay on
Check your settings, maybe you have an auto-off feature turned on. If this is not the case, seek professional help, it's probably a software problem.
Apr 07, 2010 | Westinghouse DPF-1411 Digital Picture...
When I turn the power on, the red light close to the DC power input comes on and the picture frame flashes very quickly but it does not come on. Is LCD out?
Try to see if there is a reset switch on the frame. This is usually a small hole on the back of the frame that a paperclip can be inserted into.
Feb 27, 2010 | Westinghouse DPF-1411 Digital Picture...
Westinghouse dpf 1411 wont turn on power block
I would recommend contacting Westinghouse customer service team at 1800-701-0680 for further assistance in getting this frame replaced.
Dec 31, 2009 | Westinghouse DPF-1411 Digital Picture...
Westinghouse DPF-01411 Digital Photo Frame
Things I have learned after messing with 3 different Westinghouse DPFs (1 -14" & 2 - 10").
1. Just tap the buttons. Exit first and then Menu or one of the other functions. Holding them down too long seems to nullify the functions. Only the Power button needs to be held down for a second or two to turn the device on or off.
2. Use a USB to mini-USB cable to access the internal memory. Expect flakiness when you plug in the cable. Sometimes it will warn the USB 2 device is plugged into USB1 port. Ignore this and just look for a string of removable drive letters to show up in My Computer window. The one named FLASH Drive is the internal memory.
3. I reformat the internal memory (FAT32 seems to work fine) and this gets rid of the troublesome canned pictures that may be causing your lock ups.
4. I have had good succcess the xD memory cards from 16MB to 1GB.
5. I have not seen any prblems with edited photos or long file names - just be sure they are named with .jpg extension and not .jpeg. - go figure?
Hope this helps...
Mar 30, 2009 | Westinghouse DPF-1411 Digital Picture...
Dpf-1411 locked in slideshow
To fix the freezing problem, all you have to do is change the file names to basic numbers. If you have long file names, it causes the pictures to freeze up. Change the names, and the problem stops!
Dec 18, 2008 | Westinghouse DPF-1411 Digital Picture...
Westinghouse DPF-0702 Digital Picture Frame, Digital Photo Viewer Logo
254 people viewed this question
Top Westinghouse Photography Experts
teddyboy
Tom Chichester
Tom Lahart
Level 1 Expert
Are you a Westinghouse Photography Expert? Answer questions, earn points and help others
