Question about HP Office Equipment & Supplies
Which HP printer can copy or scan legal size (81/2 X 14) documents?
    President:
  • 1,901 Answers
You will likely need an Officejet model such as this one:
Officejet L7780
Here is another, but more expensive:
Officejet 8500 Premier
And...this one looked pretty reasonable:
Officejet L7680
These were the only ones I found with legal size flatbed scanning/copying.
Thanks for using Fixya.
Posted on Jul 02, 2009
Cannot scan legal size document with windows 7
Of course it can't . Since the maximum scan size is 8.5 x 11.7 inches it cannot scan a document that is 8.5 x 14 inches which is legal size. To do legal size you must either have a large-format scanner so the glass size is large enough, or have an all-in-one that has an auto-feeder. Those use a different scan bar from the feeder and can do legal documents.
Mar 21, 2015 | HP Deskjet 3050 Multifunction Printer
How do i scan a legal size document on hp officejet 6830
You will need to use the automatic document feeder and there should be an option in the scanner software settings to tell it you are scanning a legal document.
Jan 31, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
HP Office jet plus 8600+ - supposed to print legal but does not!!?!
The printer set up procedure may reveal there is no provision for legal size printing.
May 26, 2017 | HP OfficeJet Pro K8600 Printer
Change legal size to letter size
scan it as a document, re-scale it in required size and save then print in required size.
these adjustments are in your word or office programs. if you need to make it to copy, insert your original in the scanner, in paper tray insert your letter paper, select copy and then re-size, this should do it "on the run".
Jul 26, 2010 | Dell 1815dn All-In-One Laser Printer
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How can i copy a legal document with cannon MF3200
you can print legal document through print command go to print property and give command on legal size.
but you can't scan legal document in single go.
if it urgent to scan in legal scan it in 2 parts then join using some software like corel draw or word.
Jun 10, 2009 | Canon MF3110 All-In-One Laser Printer
Can not scan legal documents
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-4
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Color Laserjet 2840 will not completely scan legal size docs
have you downloaded the scanfix that is own the HP support site?
May 22, 2009 | HP LaserJet 2840 All-In-One Printer
172 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
