Question about Rimage Autostar II DVD-R, 4 Drives, PrismPlus Printer, Standard Control Center (555311240) Burner
Prism Plus drawer does not consistently open and close. Makes a loud noise when opening & closing. Just shipped back from out of town (FedEx).
  • info38476 Jul 02, 2009
    Your answer is vague. What ring are you speaking of and how do I open the printer?
    President:
  • 1,383 Answers
You have to check ring of it. For that you have to open it.
Then you have to change ruber ring .it is fix with 2 wheel it si loose so 2 wheel are nbot move so drawer has probnlem in move ment.
Posted on Jul 02, 2009
  • kishor
    kishor Jul 02, 2009
    you can open the printer from back side.
    Remove some screw so you can open it .
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Screaming noise
spray the drawer with pam
Apr 06, 2014 | Kenmore Refrigerators
The moonroof cover was fore closed while moon roof was open and now makes noise and leaks
it sounds like something that is broken inside ,u might need a new moon roof track complete unit
Jan 27, 2014 | 2007 Dodge Caliber SXT Sport Hatchback
DVD drawer opening when it shouldn't!
With the price of dvd players and yours bieng 6 years plus it make more sense to just buy a new one.
Jan 10, 2014 | Panasonic SA-PT460
Genie worm drive garage door opener makes loud noise when in uses
My opener is making a loud noise when opening or closing! I have no clue what to check
Feb 27, 2013 | Genie Company Genie 27092A Replacement...
Home theatre (panasonic SA-PT460) drive wont open makes some noise when i press the open/close button as its closing. I unscrewed the device and removed the dvd tray from its case as i pressed the...
I also have a problem with the drawer. It opens when I switch the unit on and when I close it - it opens again!
If I switch off at the mains the drawer remains open - to prevent dust ingress I have resolved to holding the drawer in whilst shutting down the power until I get a solution.
If anyone has a solution I would be grateful.
Sep 08, 2011 | Panasonic SA-PT460
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
The top drawer intermitantly makes the drawer opening noise
On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. Wipe these areas with a clean dry cloth.
May 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Rimage Autostar II DVD-R, 4 Drives, PrismPlus Printer, Standard Control Center (555311240) Burner Logo
56 people viewed this question
Top Rimage Computers & Internet Experts
David Payne
David Payne
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
