Question about Comdial 8324S-PT Corded Phone
Fixing the time and date
I have gone threw all the steps to change the time since it didn't do it on daylights savings time. So now I have a phone that has the right time but I can't get the date to be right. Everytime I set it, the date turns to something else!!
  • Capn-bryan Mar 27, 2008
    My Comdial DX80 is displaying the wrong time due to daylight savings, but the internal time is correct. I have re-set the time in the phone several times, but the display time is still an hour off.
    Also, this problem causes the night mode to stay on an hour into business hours. Night mode is currently off during business hours, but the incorrect display time is throwing off the system.
    I have an older model DX80 (the booklet says Oct. 02)
I have had a similar problem,
I found this on
Try this: ITCM, *, #, 0, *, 01, MM, DD, YY, HH, MM, #, SPKR to end
If that doesn't work try this, some tech gave me this sequence and it worker for us: ITCM, *,#,746,*,01-SET TIME
Posted on Jan 04, 2008
How do i change the time
For Windows 10 following these steps to change the time and date:
1. Right click on the time (Normally at the bottom right-most corner of your screen, on your start bar)
2. Select Adjust date/time
3. Press Change (Button under Change date and time text)
4. Set the time/date, and press Change
You can also change your timezone, daylight savings and automatic internet vs manual time on that setting page.
Nov 08, 2017 | The Computers & Internet
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
Pacific Standard/Daylight
Yukon Standard/Daylight
Hawaiian Standard/
Daylight Time
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
To change the setting manually, follow the
procedure from step
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
until the correct year
Repeat steps
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
How do I change time and date on LG440G Tracfone?
On my model, I go to menu, then calendar, then calendar will show up & you can use arrows at the top to pick month & year, then once you got the right month, tap on correct day. that is for the date.
The time should come up automatically when you turn on your phone. Mine even changes to correct daylight saving time automatically.
Mar 09, 2015 | LG Cell Phones
I installed a Honeywell 8580wf thermostat and when I set it up I put in the correct date and time and when it hooked up to the wifi the time changed to the wrong time and it won't let me change it because...
Check your wifi time! If the wifi time is showing the same as your thermostat then change it at the router! Set it to auto time and daylight saving on!
Jan 02, 2015 | Heating & Cooling
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
May 02, 2011 | Samsung B5722 Cell Phone
Panasonic KX-T7730 - changing time display
Following are the steps:-
- *#1234
- 000
- Speaker (Date/Time will appear on the screen & blink
- Point directional sign to the desired position to change accordingly
Once finish with the above - Press "STORE" button
Then lift handset and replace
Apr 06, 2009 | Panasonic KX-T7730 Corded Phone
Daylight saving time feature
key in date and time
Mar 09, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Reprogramming the date for daylights savings time.
From extension 10 or 11
feature 00
left intercom
left intercom
press the 2 button
feature 00
That will disable it.
Apr 09, 2008 | Avaya Eurostyle 18D Corded Phone
My time doesnt change at daylight savings time
Go to settings,initial setup,time and date. change it to "off" on autoupdate.You'll get more options. You can change the date and time then.
Nov 04, 2007 | Motorola Mobility RAZR V3
Change the time
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Oct 29, 2007 | Panasonic KX-T7633 Corded Phone
Comdial 8324S-PT Corded Phone Logo
142 people viewed this question
Top Comdial Lands Phones Experts
Starnley Johnwells
Starnley Johnwells
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
