SOURCE: broken tumbler belt
Slide a putty knife or other thin object between the top and front panels a couple inches in from either side. Press in and release the two spring clips holding the top panel and at the same time lift it up and lean it back. Remove the screws inside the front corners holding the front panel on. Place the new belt around the drum in about the same position as the old one was. Remove the lower rear panel to access pulleys. place belt around the motor pulley. Stretch the idler arm over and place belt around pulley. Reassemble.
SOURCE: how to open up Frigidaire GLE0332CAS2???
Try this link, the first one the maytag one has the actual instructions, all dryers a pretty similar you just have to route the belt according to the diagram!! Good luck,, ps a good rating would be nice! thanks
http://fixitnow.com/wp/2004/08/19/appliance-repair-revelation-how-does-that-dryer-belt-go-back-on/
SOURCE: how to replace fuse dryer frigidaire affinity
If it is like any other frigidaire dryer it is mounted on the upper right hand corner of the rear bulkhead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My Frigidaire Affinity AEQ7000EGO dryer
Could be one of 4 problems:
All of the above are easy do at home repairs if you re handy. You should be able to get a good idea of what is wrong just by turning the dryer drum by hand. If the problem is the front bearing or guides, you will hear a grinding noise in the front at the top of the door.
Below is a link to diagrams and parts for your dryer. - J
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5156927
Thanks for using FixYa - a 4 THUMBS rating and POSITIVEComment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
