Question about Sony DVP-NC615 Multi-disc DVD Player
If you spin the disk it will spin and play but it will not pick it up normally. It just clicks as the laser moves on the tracks.
  • 4,234 Answers
This sounds like there is a dead spot in the spindle motor. This is not a replaceable part in your model. You will need to replace the optics assembly. This can be ordered using part number:
A-6062-709-A for $76.15 plus shipping from tritronicsinc.com
Dan
Posted on Jul 02, 2009
My cd changer wont play the cd.. it works meaning it seems to be spinning around but just suddenly says check disk. help !! i need music to drive !!! thanks
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
Jul 23, 2011 | 2002 Jaguar S-Type
Hi i am just wondering why all of a sudden my dvd wont play normal dvds but will play cds and home made dvds please help many thanks karen
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 21, 2011 | Audio Players & Recorders
Won't play a disk
Jul 17, 2011 | Car Audio & Video
My DVD player won't read, keeps saying disk error
Jul 12, 2011 | Televison & Video
When i put a dvd in you can hear the dish spin then it says to insert disk,when the disk is in there.
Apr 16, 2011 | Philips DCP750
No sound from cd player
the laser lens needs cleaned most likely, you can purchace a cleaning disk, or take the unit apart and used a eyeglasses cloth and very gently wipe the lens clean. the lens will be very small and near the motor that spins the cd. when wiping it off, wipe in one direction only. if that doesnt work then the laser has become weak or has quit working
Jan 14, 2010 | Sony CFD-E75 Cassette/CD Boombox
Hello .Sometime does not play track
It is having trouble reading the CD.
Either....Dirty CD. Dirty laser eye. Duff CD. Duff laser unit.
One More Time does not like CDs made on your computer too.
Jul 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
LD Repeats itself every 15 seconds in play, DVD's play fine.
This solution should help or at least decrease the occurances.
It has worked for me.
The problem seems to be that the original manufacturer lubrication on the glide rails and on the glide track has lost it's viscosity causing the Laser Pick-up Head gliding process to bind causing video to repeat at any random binding point.
Open the top cover and play a Laser Disc.
Manually change from Side "A" to Side "B".
Observe how the Laser Pick-up Head glides on the track and on the glide rail.
Stop play mode and remove the Laser Disc.
With the tray open, unplug the power at the power electrical cord. Now with the power removed and the tray left open, take a "Q-Tip"™ and spray some ""WD-40"­™ on the "Q-Tip"™.
Now gently tap the saturated "Q-Tip"™ along the full length of both the upper and bottom glide rails as well as the glide tracks.
Repeat this process.
Be careful not to touch or lube the Laser Pick-up Head with the "Q-Tip"™.
If you do touch the Laser Pick-up Head, just gently clean it with another "Q-Tip"™ saturated with alcohol.
When finished, reconnect the power and play a Laser Disc.
Manually change From "SIDE "A" to SIDE "B" about three times to spread the "WD-40"™ evenly and ease the gliding process.
This solution should help.
Feb 08, 2009 | Pioneer DVL-919 DVD Player
CD Player Skipping And Spinning Backwards!
Clean laser first. Near the laser there will 2 / 3 adjustable pots. Mark location on them all first. Pick one (then another) move a little left or right and see if you can get it working. If all fails return them to original positions nothing but time lost.
Apr 01, 2017 | Yamaha CDC-502 5-Disc CD Changer
Won't play discs.
Hi Crashley41,
You Laser must be burned out. Since it doesn't play any discs, I believe you have a melted laser. In this case, your disc should not spin either. You need a new laser. Click on "Repair Directory" at the bottom of this screen. Then click on "Video Game consoles" in the next Screen. Pick a good Repair shop dedicated to Playstations. You can probably get a good deal on getting your Playstation working top notch again. Good Luck
Nov 23, 2007 | Sony PlayStation 2 Slimline Console
Sony DVP-NC615 Multi-disc DVD Player Logo
273 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
