how to replace a steering rack on a 2006 dodge dakota 4x4
SOURCE: 2001 Dodge Dakota loose steering
Hello
Welcome to FixYa
there is a u joint to be replaced on your steering shaft just after the steering shaft
open the hood look down to the steering shaft you will see a small u joint very common to go bad most auto parts stores carry the part
RD
SOURCE: is front drivers side wheel
depends on what you mean by "hard" if your mechanically inclined no, if you aren't, yes. You will need to remove the tire, the brake assembly and then get a large (32 or 34mm probably) socket to take off the spindle nut, I think on the dakota you have to remove the ball joint with a ball joint separator, remove the bearing assembly from the half shaft. (standard procedure on most vehicles) Hope this helps!
SOURCE: 2006 dodge ram 2500 4x4 diesel replace brake pads front and back
Straight forward job. Remove wheels, remove 2 caliper bolts per wheel, check bolts,and bushings for wear/corrosion and lubricate, remove calipers, remove brake pads, push caliper pistons into calipers, replace anti-rattle clips, put new pads in, put caliper and bolts in, put wheels on. Start truck and press brake pedal several times to take up slack and you're done.
SOURCE: steering come and goes.no fluid lost. no noise 2004 Dodge Dakota
the power steer pump is faulty
SOURCE: Power steering
i have a 2001 dodge dakota 3.9 2 wheel drive pickup.Power steering resovior is leaking.Need any tips on replacing it. Thanks. Rick
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy
Silverado 2500 HD?
http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
Rack and Pinion Steering Gear on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota
cruiser?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
How to replace Power Rack and Pinion Steering
Front Drive Pinion Seal Removal on Ford
Explorer?
http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange
& Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion
Steering Gear On 2007 Ford Taurus?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion
Steering Gear on Ford Windstar?
http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack &
Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac
Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Rack & Pinion Steering Gear on Mercedes Benz Truck?
http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
Rack & Pinion Steering Gear on Toyota
4Runner?
http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion
Steering Gear Replacing on Toyota
Land
Cruiser & Sequoia?
http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear
Removal on Toyota RAV4?
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
Steering Gear on Toyota Sienna?
http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
