Question about Freezers
I have a fridge freezer and found a small pool of water at back on floor
    Problem Solver:
  • 6 Answers
The drain hole at the inside bottom of your fridge freezer is blocked. locate and unblock
Posted on Jul 02, 2009
Freezer drain is clogged, I guess, water dripping on the floor, ice buildup on bottom of second door, it has an ice machine built in, what do I do? I'm a female.
Good Morning Andi.
the good news is that the fridge is not likely doing this because you're female, and your description of what has happened with power outages sounds like that's very likely the culprit - a fair amount of melted water dripping, then power comes on and freezes water in the drain.
I don't know your specific model, or if you know where the drain is. it's likely down in the bottom of the freezer compartment. If you remove the lower drawer, or unpack the lowest area, the floor will likely slope toward either an overt hole, or to a slit/hole in the back. If there is actual ice frozen on the lowest shelf/shell of the freezer, you'll want to get rid of it.
Easiest and safest route (as in least likelihood of damaging the freezer or hurting anyone)
  1. Turn the fridge off. It won't be off long enough to risk much thawing, but you don't want the cooling coils actively pulling heat from what you do in the next step.
  2. Hot, even scalding water. Especially if there is overt ice at the bottom, pour small dribbles in at the edge. Some will go across the ice and melt a bit of the bulk. Some will trickle down between the ice and the freezer floor. Do this a couple times, then see if you can pry up sections of the ice from the floor. Pull out as much as you can of the bulk ice. You'll likely want to get a couple of towels out since you'll likely get some water on the floor.
  3. Once you've cleared overt ice from the freezer floor, pour some more hot/scalding water onto the plug, or into wherever the floor slopes to. Be patient and don't pour too big a volume. Ideally, after a few modest pours, you'll get water coming out from under the fridge. If the lower panel will pop loose, get in and use a towel to pick up as much of the water as you can. pour a bit more hot water through and verify it pours through to the floor (or possibly a catch pan).
  4. If you get this far, dry the freezer floor as best you can with the towels, replace the drawer or any unpacked foods, close the freezer, and turn the fridge back on. It will probably be back to normal.
    Good Luck!
    D
Nov 23, 2015 | Freezers
Frozen water on bottom of whirlpool model evl181nxtq01
I assume that the water is on the bottom of the fridge compartment? It could be that the drain trough has blocked and every time the fridge does an auto defrost, water runs out onto the floor of the fridge rather than down the drain. Once the defrost finishes, the water will stay on the floor of the fridge. Cold air falls to the bottom so its possible to get a sheet of ice in the bottom of the fridge. Locate the drain trough in the back wall of the fridge. See if you can visually locate any blockages or carefully dribble warm water down the drain to clear it.
Oct 19, 2013 | Whirlpool Freezers
Whirlpool fridge freezer
either the return air grill(small grill on the inside wall of fridge) is blocked with a loaf of bread or something, or it's the freezer drain is blocked, some fridges use the drain as a return air vent,after unpluging it from the power point, defrost the fridge a remove the back wall plate (interior) of the freezer , & push something down the drain line like whipper snipper cord etc. then poor really hot water down it, check the drain at the back of the fridge for water running, reassemble the fridge pug it in & you should be sweet
Jun 02, 2013 | Freezers
My Daewoo ERF 334M Fridge/Freezer has a little ice in the bottom of the freezer and is spilling water onto the floor - think it may be a blockage in the drainage pipe but do not know where this is located...
it go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
Aug 15, 2011 | Daewoo ERF336MB Freezer
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
78 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
