Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
After3 years of service suddenly wont start-no evidence of power,circuit ok. Is there a re-set mechanism? Help. Thanks
  • 85 Answers
Hello dcrerar,
I think I can help you.This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
My evesham pvr160 suddenly wont power on - fuse is ok.
Check its power cord first. If found OK, check and replace damaged component/s at its main power regulator section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 02, 2014 | Evesham PVR160 Freeview 10-Hours Video...
Philips powervision tv
A white horizontal line on a tv is an indication that your vertical circuit is defective. Very common for the vertical IC to go bad. The fuse in a TV set is only there to keep your house from burning down if there is a problem. Your set has a problem. In my area repair should cost you about 100 to 120$. Tube Tv sets have about 5 years of expected life. I would invest my money in a new LED set.
Mar 14, 2014 | Televison & Video
99 Elantra suddenly died
I'm not sure of this, but my friend experienced similar situation.
He had a Kia Pride used for Taxi cab. He have replaced damaged parts, replaced freon for his aircon and overhauled the engine. The cab really runs smoothly and in good condition.
But from time to time, the engine stops. Just like you, everything is normal, but stops unexpectedly. We even have it checked from my friend mechanic and said that everything is normal. He gave up the car and he loosed around PhP50,000.00 at that time (enough to pay rent for a year. He later found out that the car runs OK again...
THE NEW OWNER HAVE THE WIRING AND ELECTRICAL CIRCUITS RENEWED!
And a car owner claims for the same problem, I said its ELECTRICAL CIRCUITS, it should be replaced. When she have it fixed, the mechanic have her car's wiring replaced. And it runs smoothly again.
Please try...
Aug 22, 2012 | Hyundai Cars & Trucks
Suddenly the lens began going in and out and now it is stuck halfway out. Someone suggested banging it to unsyick it but that did not help. Our local camera shops do not work on Sony cameras. Any ideas?
The Lens may start going in and out when the Lens mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the issue, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required. For getting the unit serviced, you have to contact the Sony Authorized service centre or factory service centre. You can contact Sony here.
Thanks for using FixYa.
Jan 04, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
Was hiding the evidence that I bought a new transformer, threw box & directions away! Need help in setting the clock, lights keep coming on at 4 in afternoon, would be ok in Alaska but i live in...
Sounds like a stupid answer, but make sure the timer wheel is rotated to the correct time. Also, make sure the on/off trip pins are set to the correct times. It is common for the time to be off if you ever lose power.
Jul 02, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Tripping circuit breaker
what suddenly starts to opperate every couple of days
Jan 13, 2010 | Steamist SM-79 7900
Light wont start up
You will have to Replace the Balast.
Jan 18, 2009 | Hydrofarm Flc0125d Fluorescent Grow Light...
Tv wont turn on at all
First off I usually check The horizontal output and the Low voltage regulators for shorts or open conditions.Followed by checking capacitors ,resistors and diodes in the power supply. Do you have a service manual for your set? That will give you the various test points and what the voltages should be to help nail your problem down. You'll need to be cautious around the capacitors as you can get shocked even with the power disconnected. If you dont have a manual you can probaly get one at this link. Hope this helps. Let me Know if you have any questions . http://www.servicemanuals.net/ Here is another link for manuals http://www.smshop.org/
Jan 05, 2008 | Televison & Video
Projection tv wont turn on
i had same problem after house power switched off 3 times in same day disconnected power left overnight worked ok i will still take tv for a service .
red light was blinking 10 times
Sep 27, 2007 | Televison & Video
Tv will not power up
no reset button ,sorry. The problem you describe is pretty common with this model as its a fault in the horizontal drive circuit or in the main power supply and without the proper service manual as well as the prober tools and equipment this set its not gonna get fixed. there are no panels or user changable boards as it is a solid state set. ptscorp.com could repair this board or exchange it with a referbished board but it would still requir some adjustment that a user may not be able to handle. time to call the pro.. Sorry couldnet help ya more.. Good Luck.
May 23, 2006 | RCA MM36110 36" TV
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
553 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
