Question about Nokia 6300 Cell Phone
No signal after washed - Nokia 6300 Cell Phone
  • hanungtejo_p Jul 03, 2009
    hi marrk26,
    thanks. But could you give a specific solution, or maybe you could provide a block diagram for this kind nokia series..and determine which part or ic is having problem or need to repalce...
    thanks n regards
    tejo
First thing to do is.. if you have knowledge in electronics you can fix it... open your phone remove battery, remove casing, remove mean board to back housing... the Guide how to open it is HERE this is not a china phone service manula but it s looks like and simelar in your phone... now suppose all are ok.. wash your phone in ultra sonic or tinner soak it 10 to 15 mins then dry it using any heat or hot air.. make usre that all liquide was remove from your phone... if yuu have a multi tester you can check it by testing the both (+) & (-) of the phone battery Terminal... ( this is for expert technician only) reinstall you phone and test if all is ok.. make sure that the battery is fully charged..
Posted on Sep 22, 2009
  • 42 Answers
water went inside of or mobile and affected some circuits in the board.
prefer to advice that bring it to a service center and let them fix it personall for you.
thanks,
Posted on Jul 02, 2009
Whats mean signal EC
Error Code? This is NOT a CD player washing.
Dec 20, 2012 | Audio Players & Recorders
Error signals during wash
What is your make model number of your unit? What is the error signal?
Nov 01, 2012 | Washing Machines
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Error signal appears and wash machine stops
clean out pump and drain hose you have blockage may need to do many times until opened
Feb 05, 2010 | Frigidaire ATF6000ES Front Load Washer
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Nokia 6300 Cell Phone Logo
102 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
