Question about Balance CM2019 19" LCD Monitor
Signal not in range-have to restart - Balance CM2019 19" LCD Monitor
  • 60 Answers
Your resolution is set too hight, reboot computer pressing F8 untill you get a list of start up options, one of these will say start in safe mode, press enter on this and allow the computer to boot up, once it has finished,right click my computer click properties then click on hardware then device manager, click on display adaptors then right click on the adaptor in the list and click uninstall, close everything down and reboot the machine. when it boots backup it will reinstall the drivers automaticaly and set to a lower resolution,
Posted on Jul 02, 2009
Bluetooth connectivity issues
My router extender did that once. A simple powered down and restarted fixed it. I hate to sound like Comcast which always tells you to do that but it's worth a try with wifi and bluetooth. Also obvious but check the battery, when it gets low enough the signal gets weak before it actually stops. Cellular telephones do the same thing. A low battery can affect signal strength.
Mar 16, 2014 | Motorola Radio Communications
When OS starts I received an over range signal and my monitor turns black
1. restart your computer
2. change it to safe mode
3. change your screen resolution to lower
4. save and restart . .
have a nice day
May 10, 2011 | Computers & Internet
1993 pontiac grand am 3800 v6.codes 22,31,and 34.engine dies and sometimes won't restart for awhile....why? any help would be greatly appreicated,thanks
22 is tps sensor signal low--31 is cam sensor fault---34 is map sensor signal out of range. have a great day!!
Oct 18, 2010 | 1993 Pontiac Grand Am
The monitor keeps going blank with a message ''no signal'' or ''out of range''.
Probably you are out of the resolution range for this monitor. Try to boot you computer in safe mode (for low resolution) using F8 just before the windows start screen, step down the resolution, restart and try step by step to upgrade the screen resolution.
Stelios.
Feb 21, 2010 | Computers & Internet
'04 Trailblazer. Indicator shows drive but it's not in drive.
The transmission range (TR) switch is part of the park/neutral position (PNP) and backup lamp switch assembly, which is externally mounted on the transmission manual shaft. The TR switch contains four internal switches that indicate the transmission gear range selector lever position. The powertrain control module (PCM) supplies ignition voltage to each switch circuit. As the gear range selector lever is moved, the state of each switch may change, causing the circuit to open or close. An open circuit or switch indicates a high voltage signal. A closed circuit or switch indicates a low voltage signal. The PCM detects the selected gear range by deciphering the combination of the voltage signals. One of these circuits it what is causing your problem but I hope this helps you understand some.
Jul 06, 2009 | 2004 Chevrolet TrailBlazer
Out of range
Setting the Refresh Rate in Enable VGA Mode - Windows XP
You will need to go into Enable VGA Mode to change the refresh rate.
  1. Restart the computer and repeatedly tap the F8 key on your keyboard until the Windows Advanced Options Menu appears.
  2. Select “Enable VGA Mode” and press Enter.
  3. If asked to choose your operating system just press Enter.
  4. Once the computer has finished booting up go to Start -> Settings -> Control Panel -> Display -> Settings -> Advanced -> Monitor.
  5. Change your Refresh Rate/Refresh Frequency to a lower setting.
  6. Click Apply to confirm the change.
  7. Close all open windows and restart your computer.
* Click here for help determining the optimal refresh rate for your monitor
Sep 24, 2008 | Computers & Internet
Input Signal Out Of Range
press F8 upon booting up instead of choosing safe mode click ENABLE VGA right click desktop, click properties, click settings, set resolution to 1024 x 768 from there you will not see anymore the Input Signal Out Of Range
Apr 11, 2008 | Akai LCT2060 Television
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
Wireless G ranges expander
when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 192.168.0.240. once that is done restart the range extender and disconnect the ethernet cable & it the 2 lights should light up blue.
Jan 20, 2008 | Linksys Wireless-G Range Expander (WRE54G)
No signal - out of range
Start the computer.
After the ios info page/motherboard page is gone, start to press F8 a few times.
If you still get to the point that you see the Windows Logo loading screen, then press reset and try again.
If you have done it correctly, you will get to the Windows boot page.
Select Safe Mode and start Windows
Go to the video properties page by right clicking anywhere on the screen and adjust the video mode to 640x480 (or as low as it will go)
Restart the computer and see if that solves the problem.
If not, then do the same procedure, but go into system properties and unistall the video card.
Restart again, and install the drivers if needed.
Hope it helps.=)
Apr 23, 2007 | BenQ FP71G+ 17" LCD Monitor
Balance CM2019 19" LCD Monitor Logo
63 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
