Would a 2N3055 make a suitable replacement for a 2SC1667 transistor? The 2SC1667 is from a Leak reciever - the main amp section they are used as the main amp.
  • 4,234 Answers
Since the 2SC1667 is still available, why substitute. The exact part can be ordered. Substitutes are fine if hte original is no longer available, but you should use the original when you can.
Dan
Posted on Jul 02, 2009
  • rbmrsm Apr 23, 2011
    I agree with Dan although the 2N3055 might work OK in an audio amp. If the amp is stereo and uses these as outputs you must replace both if you change the type. Otherwise you'll likely have an imbalance in channels. Note that the 2N3055 is a 150Watt power transistor and my use more power and strain the other components.
Horizontal transistor
2n3011 2n3055 are generic parts, really need make and model of the tv. Some sets are picky.
Nov 26, 2014 | Televison & Video
No power sharp 21v-w70m
Short circuited component at its main board. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Give a special attention to its horizontal output transistor. Replace it, and check. Check this device for collector to base, or collector to emitter leak. Even a slightest leak, will cause sivere problem.
Apr 16, 2014 | Televison & Video
Keeps on blowing fuse
Hello
If fuse blows off repetedly, it shows that there is a direct short inside the power supply section. You just check the mains rectifier diodes for short. iIf a rectifier stack is used desolder it out and check for short. In some sansui sets, ther is a metal oxide variste connected across the supply line inside directly. It is for line spike suppression and an overvoltage protection. If any of the above appears on the power line, the varistor will get shorted, and the fuse will go out, to prevent further damage to the circuits. Check that varistor for short. Check the resistance across main filter capacitor for any direct short. If it seems shorted, check the switching transistor for collectror to emitter leak, Resolder it out and check. These are the main reasons for blowing fuse. If the switching transistor has got leaked, you must check the entire SMPS control section, especially in case of used zener diodes, before replaceing a new transistor. OK.
If you wants anu further assistance, inform me through Fixya. Ok.
Nov 05, 2010 | SansuiS2746 TV
Output stage scheme for pioneer vsx-d1 channel floating negative.
It should be a push pull. The fact that you have negative voltage almost certainly means push pull. One side will be constructed using NPN transistors ran off the positive DC rail and the other side will be constructed using PNP transistors ran off the negative rail. I don't know the age of your amp but I know pioneer now uses integrated amp modules instead of discrete transistors.
http://pdf1.alldatasheet.com/datasheet-pdf/view/82968/SANYO/STK412-020.html
example of integrated amp module (sorry for the chinese)
Feb 11, 2010 | Audio Players & Recorders
Ihave a technics reciever model sa-g90 it plays then it trips and shows overload. what should i replace?
Check out the power supply parts first. Then check out the main amp section (on the heatsink).
Look out for burnt or damaged parts. If it uses transistors and you have a ohm meter, test them for shorts. IE one probe on one leg and the other probe on another leg of the transistor. If you get the meter behaving like the probes were touching one leg it's shorted.
Jan 13, 2010 | Audio Players & Recorders
Pyramid ps-15kx
Unplug the PS-15KX 120V AC cord !! Then take cover off. DO NOT plug the AC cord in unless you are used to working around a lethal voltage and current !!!!!!!!!!
If you can use a Multimeter, then measure resistance across each pair of the 3 leads of the output transistors. You will probably find fractions of an ohm across a pair of leads. One or both may be shorted. NOTE: Do not ever measure resistance in a powered up circuit, kiss meter bye-bye and maybe burn you too.
By putting more robust transistors in this supply, you may not gain much reliability. The supply is rated at a continuous current draw, which is less than the intermittent current they advertise. Read the spec's of any power supply you get and look for continuous current ability.
There are several better transistors that will substitute for the 2N3055. You will need to look at a transistor substitution book and check specs. The internet is great for this. I used to use all kinds of data books, and still have them! But looking up info on-line is nice. Motorola has some that will fit and have higher current and voltage ratings,
Get someone who is a ham or geek if you aren't sure about sticking your fingers in the power supply.
Be Careful, Work Safe, it is a factor of longer life.
Nov 08, 2008 | Pyramid 10 Amp Power Supply (068888701655)...
C5707 available at?
from an old post (at Dell):
The TIP3055 handles about 70V and 10 Amps and is an NPN, so I decided to purchase four 2N3055 TO220.
from another one:
was able to successfully directly substitute MJE3055 NPN transistors for those on the original board
They are "equivalent", but (much) bigger: you must do some bending for them to fit inside the chassis
Ro
Sep 09, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
309 people viewed this question
 Grubhead
Grubhead
