Question about KDS Computers & Internet
I have a older kds lcd monitor that goes black less than 1 min after turning on, the power light stays on, the monitor will come back on if you repower the monitor then goes back off in 3 or 4 seconds. Is there a easy fix or should I replace the monitor ?
  • 60 Answers
If you look closely can you see a very dark image on the screen? your problem is usually the result of the backlight on its way out, these are very hard to replace so you will need to take it to a profesional, in most cases it is cheeper to buy a new screen.
Posted on Jul 02, 2009
  • bIll Colipietro Sep 15, 2013
    I have a 17S monitor gone black HElP KDS
Kds K-92bw After about 5 min the screen goes blank..turning the unit off than back on the screen looks great for a while about 3 min than goes black..seems to be a caused by heat
This issue is most likely caused by a capasitor doing bad. There is no easy fix. It must be disembled and the power supply repaired. If done properly, it should cost somewhere between $ 50 to $125. But it may do it again as the Pwoer supply is a known issue for this monitor. Sorry.
Sep 21, 2011 | KDS K717s 17" LCD Monitor
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Hannspree HF229H will not stay on
railbird56, Common problem for ALL BRANDS of "cold-cahtode-fluorescent-lamp" back-lit lcd monitors! Here are your options!!! Cheapest to most costly!! 1. Warranty repair. 2 DIY repair???? 3. Local or distant repair. 4. possible old + cash swapout with Hannspree for refurbished same model?? 5. Trade-in for new wide screen. My best guess on your monitor (no history) is that the unit's SMPS is in partial or full shutdown mode during it's black screen moments. How much do you know about "electronic ballasts" "switch-mode-power-supplys" and how to repair them?? 12fixlouie
Feb 22, 2010 | Hannspree HW191D LCD Monitor
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
After 15min the monitor cuts off. KDS k717. Iturn it off for a few min and turn it back on and it does it again
power converter/supply bad defect contact manufactuer and ask for warrenty replacement
Mar 13, 2009 | KDS K717s 17" LCD Monitor
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Screen goes black
Check and make sure the software is updated on the set.
Aug 19, 2008 | Televison & Video
Monitor stays black
First make sure you have the monitor cables correct. Try another monitor hopefully works so you can go into your device manager and make sure the right drivers are loaded and that your monitor is listed. You may do some research because I'm not sure but I think your monitor uses a back light & an inverter which is replaceable and not usually a difficult job or to expensive. Labor of coarse cost more than the parts. Monitors use a video card or on board video so make sure these are not the problem.
Are you sure its not in wake mode in the bios?
If you shine a light on the monitor when the comp. is on and the monitor light is on you may be able to see your screen. That would be the back light.
When if all and what was going on when it stopped working?
Jul 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Computers & Internet Logo
254 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
