Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
WD 320 Gb hard drive not working on my Pc but is working fine on
WD 320GB external hard drive works fine on one computer but when I connect it to my PC is shows up for 2 sec and goes away
  • matthewr41 May 11, 2010
    On the PC that "it goes away," are you using a hub, or directly plugging into the PC's ports? Also, are you using the short cable that came with the drive? Using a longer cable on these usually means trouble.
  • LxRiXta May 11, 2010
    Have you tried another USB device in the same socket or using a different USB socket on your system?
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Wd 320gb driver
If the drive does not appear in Remove Device but does appear under computer you can right click on it then select EJECT.
Dec 03, 2013 | Western Digital Elements powered by WD 320...
My Ovation 320GB external hard disk is not showing on the computer when I plugged in although the red light is on. There's a sound from the disk but after that while it just remain quiet and nothing...
I would try to plug it into a different USB port on the computer or try and see if it works on another computer. It could be that the computers USB port is no longer working or that the drive has failed.
Mar 29, 2011 | Western Digital Elements powered by WD 320...
Hi i`ve just bought the wd elements 320gb yesterday. the problem is that i put the usb in and the light on the product is on but thats all. its not installing and i cant find it on my computer.
The obvious question first is the drive connected with the provided AC adapter?
Are you connecting it directly to a USB port or powered USB Hub? This is not important in external hard drives but it does on portable HD. But just in case keep this in mind.
Other thing is that you have to install the WD Smartware software.
If nothing works, try it on another computer.
If it works, must be a USB port problem.
God Bless You!
Feb 05, 2011 | Western Digital Elements powered by WD 320...
WD external hardrive(320 GB). Every time i connect it to any computer , the computer stops responding. But the computer dictates that there is an external hddrive connected.
Does this happen if you connect it to a different computer?
On the other computer, virus-scan all the files on the drive.
It could be a computer-virus that is getting launched
when you connect it.
Is it your computer's virus-scanner that is trying to "scan" EVERY file, when the drive is connected?
Start the Windows Task Manager. Connect the drive,
and watch the "Performance" tab, to see what resources are being consumed.
Aug 30, 2010 | Western Digital 320GB MyBook External USB...
Internal 320 hard drive into external
If you got a USB casing for that, it would have come with a USB and power cable. Yes, power too!
Plug the power, and make sure you have a USB 2.0 hi-speed port. Also check "computer management" and check the hard disk works.
May 24, 2010 | Western Digital (WD3200JS) 320 GB Hard...
WD 320 GB ceased spinning
ensure it hasnt damaged and that you didn't passed a magnetic field through it, so that you damaged the sytem files of the hard drive...
Sep 16, 2009 | Western Digital Passport 320GB External...
HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
Dec 23, 2008 | Western Digital My Book Essential Edition...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
209 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
