Question about Whirlpool GSC9455 Top Load Washer
Washing machine does not wash nor rinses
My washing machine does not go to the washing cycle nor the rinse, it only making a humming noise
  • 112 Answers
Take it to the shp for servicing
Posted on Jul 02, 2009
Washing machine switches on and then hums and clicks the dial but does not operate just hums and clicks
Mind does the same thing, I'm not sure if it has to do with age or if it is time for new timer! mine does finish it's cycle, and wash's and rinses the cloths, does Yours? and it only does this in between wash and rinse cycle! The noise You hear is the timer making it's way through cycle, as I said I think it has to do with age, and in the future, hopefully a long ways into the future, the timer will need replaced! If This does this when You first start wash, then You may not be getting water into Your washer, Do you use city water or well?
Apr 03, 2017 | Washing Machines
Wash machine fills up starts cycle then stops it dont go to rinse then will start making a humming noise
it has bad cycle timemer switch in it replce with new one about 80.00 dollars
Dec 24, 2014 | Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washing machine gets stuck in the rinse cycle
try cleaning the valve filter on the cold inlet
Apr 21, 2012 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool GSC9455 Top Load Washer Logo
136 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
