Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Powersurge made my HD setting revert to low def.
How do I reprogram my set for HD? My remote control works intermittantly.
  • 4 Answers
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Posted on Jul 09, 2009
I need to reprogram my Sony RM-VZ220
If there is a set-up code to Toshiba TV to this Sony remote; you can set it up. In most cases, there won't be a code with Sony remote with Toshiba. Anyway, if you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Jun 22, 2014 | Universal Remote Control Hampton Bay...
What does the code po753 refer to
Symptom:
P-0753 TRANS 3-4 SHIFT SOLENOID/TRANS RELAY CIRCUITS
When Monitored and Set Condition:
When Monitored: Continuously with the key on.
Set Condition: This code is set if the voltage detected on the 3-4 Shift Solenoid Control
Circuit at the PCM is different than the expected voltage.
POSSIBLE CAUSES
FUSED B(+) FEED TO THE TRANS CONTROL RELAY OPEN
3-4 SOLENOID WIRING HARNESS INTERMITTENT DEF
3-4 SOLENOID WIRING HARNESS OBSERVABLY DEF
SHIFT SOLENOID CONTROL CIRCUIT OPEN
SHIFT SOLENOID CONTROL CIRCUIT SHORT TO GROUND
SOLENOID AND HARNESS DEF (SOLENOID CONTROL CKT)
TRANSMISSION RELAY OUTPUT CIRCUIT OPEN
TRANSMISSION RELAY OUTPUT CIRCUIT SHORTED TO GND
PCM DEF (3-4 SOLENOID/TRANSMISSION)
PCM DEF (TRANS 3-4 SOL/TRANS RLY CKT)
POWERTRAIN CONTROL MODULE DEFECTIVE
SOLENOID AND HARNESS DEF (SOLENOID PACK CONN)
TEST COMPLETE
TRANSMISSION CONTROL RELAY DEFECTIVE
Feb 03, 2012 | 1999 Dodge Dakota
Does not have 1080p
You need a high definition signal aka high def cable, blu-ray dvd player etc...If you don't use a HD source you will not be watching HD.
May 28, 2010 | Samsung 58" 1080p Flat-Panel Plasma HDTV
Band of dot's(millions) across screen only whilst watching in hd mode and whilst using any menu option such as volume etc. dot's not there whilst watching any sd programes
I think I have a good idea of what you're experiencing.
Our minds are so set in the low-def mode that when those extra lines are filled in for high-def it looks like a bunch of dots. Notice everything is so much more clear? I thought the same thing when I watched my first blu-ray disc.
Watch something in high-def and then go back to standard immediately after. You'll notice that you can't get near as much detail off of the low-def.
Those dots are your mind trying to put high-def into low def.
Hope this helps; please rate my solution accordingly
Respectfully,
Don
Feb 05, 2010 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Freeview
go to menu settings, channel settings, set tv to CATV for cable, AIR for analog, or HD for high def.
Make sure you have the correct cables depending on your connection
Sep 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Speaker volume is not audible
if the speaker system is set up right , then it could be a problem with your audio def`s go to either (if your using windows) volume controll panel , or realtek controll panel and make sure its all set right .
to make sure your speakers are ok , just plug them to an mp3 player or something and see if everything is cool.
good luck!
Jul 29, 2009 | Altec Lansing ATP 3W Computer Speakers
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Oct 24, 2007 | Gigabyte GA-945GM-S2 Motherboard
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
260 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
