Question about HP DeskJet 940c InkJet Printer
My HP 940c prints blank sheets.
My HP 940c has been a real great workhorse. Uses little ink and prints quality copies set on DRAFT. A few months back (on cooler mornings) the first page would come out very light at the top and then be fine by halfway down the page.. mostly B&W printing. Last week it started printing blank sheets. I replaced the cartridges and still the same. I get no error message.
    President:
  • 1,383 Answers
Make sure you fix ink cartrdger in exace position there is unique position for both b/w and colour.
So check it.
A;lso check your both ink cartrdges has same ink levle shke both then check.
Also go to control panel then printer and faxes then right click on your rpinter and go to property.
then go to prinitin preferences then check paer /quality set quality as NORMAL and colour as COLOUR
Posted on Jul 02, 2009
Ink is low epson me10
if your ink is low, you need to buy more ink. OR you can buy ink refill kits ( super cheap ) just be careful filling the ink cartridges so you don't over fill.
If you have only printed a few things ( photo's aside) and are low on ink, then try NOT printing the best quality. adjust the ink quality settings in the properties when your about to print.
Note: if your just printing text and it's not for anything super important ALWAYS go with draft. it prints faster and uses a lot less ink.
Jan 01, 2014 | Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer - printing any kind of document, from many formats (docs, pdf, photos) takes more than 15 minutes for one page to print. Tried restarting computer, printer,...
When you click to print something, you will get what's called the Print Dialogue box. Before clicking "OK", click the Properties button.26849353-6c28-4abb-ab9c-b5e445a1b08b.jpgThis will take you to a screen with some tabs. Click on the Paper/Quality tab. Somewhere in that window you will see some options for "Print Quality".
By default, it is probably set to "Normal". That's the middle setting. To save ink, you can set it to Fast Normal (better for ink saving) or Fast Draft (best for ink saving). This means the printer will use less ink to print the page. The final copy will look a little lighter but certainly still readable.
This option "fast draft" will print very fast and also save your ink.
Oct 16, 2013 | HP Officejet 5610 All-In-One InkJet...
I just bought a hp photosmart c3140 tri-color cartridge. after 8 small prints the ink low level lights flash-rendering my printer unusuable. i re-fill the tri-color, and reset the printer. still the...
I would be taking it back to the place of purchase and asking them to replace it. Or contacting HP directly with the problem.
You can contact HP via their home page of their website, or use the link below for troubleshooting and support:
http://welcome.hp.com/country/au/en/support.html
NOTEs:
1. Unless you are printing a final copy of an item it is a good idea to always print in Draft Quality (to save your ink). HP Printers allow you to do this. This setting is generally within the Print window, when you select Print.
2. When you are printing a final copy then switch from DRAFT to BEST quality.
Feb 10, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
The ink cartridges need to be replaced very often epson 810
You can try to change your print quality to a lower setting. This saves a lot on toner. If you are not printing for anything super important you can set some printers to "fast draft" or "draft" quality and that saves a ton. I personally dont usually need to print anything of high quality so I went to my local "Everything" store(not sure if I should use company names) and bought an HP, the cheapest color printer they had which was $30.00 The black and color cartridges together cost about the same as the printer. But I use the lowest setting which is the "fast draft" setting and set it to print in black ink only, and only change that when I NEED something in color and it uses very little and prints very fast.
Aug 10, 2009 | Epson Stylus Photo 810 InkJet Printer
HP J4680- change copy settings so printouts are fast draft
Change settings and copy from HP Solution Center
  1. Open HP Solution Center.
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: Click the Start icon (c01319360.gif ), click All Programs , point to HP , and then click HP Solution Center .
  2. Click Make Copies . The Copy window opens.
  3. In the Paper section, click A4 on the Size drop-down list.
  4. In the Start Copy section, click Black or Color .
  5. In the new window you can also change the copy settings
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Noise when beginning to print or copy
Mine always makes noise too, I don't know why. But I know that it's a lot noisier when paper quality is set for draft, so you might want to check that.
If you just go into the printer properties, under the tab that's something like Paper/Quality. There will be a drop-down list where you can choose the quality of your print out, i.e. Best, Normal, Draft or FastDraft. If it's set for Draft, you might want to change it to Normal. Draft uses less ink, but it also doesn't come out quite as clear, and is very loud.
Mar 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
Won't scan, copy, or fax
You need to change the ink cartridge, the fact that it prints in fast draft is because it does not use as much ink to print as normal letter quality.
Jan 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
COLOR NOT VIVID
The DeskJet 940c is not really the highest quality printer out there on the market. However, having said that, the printer is still capable of producing decent quality printouts. You might play with your printer settings for print intensity, lightness, ink volume.
May 10, 2008 | HP DeskJet 940c InkJet Printer
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
HP DeskJet 940c InkJet Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
