Question about Dishwashers
Doesn't drain. I replaced the disposal yesterday, and jiggled the drain hose, but it appears to be OK. I'm guessing the problem is not related.
    Sergeant:
    Champion:
  • 235 Answers
Did you take out the little plug that comes in the disposer? The one that allows water in from the dishwasher ?
Posted on Jul 02, 2009
Will not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 03, 2009 | Whirlpool Dishwashers
Water does not drain
Hi
Thanks
Rylee
Dec 03, 2009 | GE Dishwashers
My diplomat dishwasher wont drain
Hi
Thanks
Rylee
Nov 21, 2009 | Dishwashers
My dishwasher keeps washing, doesn,t go through the cycles, i have to push cancel and drain.
Hi
Thanks
Rylee
Oct 27, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwasher won't drain
Hi
Thanks
Rylee
Oct 22, 2009 | KitchenAid Dishwashers
Triton triclean not draining
Hi
Thanks
Rylee
Sep 26, 2009 | GE Dishwashers
Pluged drain
Hi
Thanks
Rylee
Sep 06, 2009 | GE Dishwashers
Dishwasher wont drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 29, 2009 | Frigidaire Dishwashers
Diswasher does not drain after rinse.
Hi
Thanks
Rylee
Aug 20, 2009 | Maytag Dishwashers
Water not draining kenmore dishwasher
Hi
Thanks
Rylee
Aug 20, 2009 | Electrolux Kenmore 24 in. Built-In...
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
