Question about Acer Computers & Internet
My Acer Travelmate 2312 doesn't boot up!
My Acer Travelmate 2312 doesn't boot up, the LED of the hard disk flashes three times, I verified the soDIMM (1 of 512 MB PC2700 333Mhz) and is burned. I tried to put a Kingston memory (with the same characteristics) but the laptop continues to do the same problem. Tried in both slots.
Screen No Back lighting. can bearly see icons or cursor
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2013 | Acer TravelMate 3260-4874 Notebook
Acer travelmate 4000 turnon light is on but display is black
Jan 10, 2013 | Acer Aspire 1640Z Notebook
Hi I have an Acer Travelmate 6492 first I wanted to reset it to factory settings I could not manage that & now it is not booting it's just flashing on top
Seems like your hard disk is not getting detected.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Start tapping the DEL key as soon as you power on the computer.
This will take you to the BIOS screen.
If it doesn't, you will have to check whether your hard disk is faulty with a local technician.
Once you get in to the BIOS screen, press F9 to load the default settings.
Than press F10 to save and exit.
Once you do this, the computer will restart.
Hope this helps.
Dec 21, 2010 | Acer TravelMate C112TCi-SP2 Tablet PC
Dsk drive will not open and acer will not boot
When you bootup and the power LED is on and the hard disk is spinning and the hard disk LED is flashing, then the hard disk is most likely OK.
Check the BIOS setting to see if the hard disk is detected.
Reseat the RAM moduled and the hard disk and see if this solves your problem.
Do you see any error messages on the screen?
If so please give me the details and I can advise what actions to take next.
Jul 16, 2009 | Acer TravelMate 290 Notebook
How do I re-format Acer 4200 TravelMate hard drive?
Windows Reinstallation Disk option:
Insert Windows Reinstallation disk into tray, Boot to CD/DVD-ROM by pressing F12 at initial boot screens, delete existing Windows partition, re-create partition, and then follow steps to reinstall Windows. This will lead you to an option for formatting hard drive. I recommend choosing the full format versus the quick, from this point you can let windows install, or just shut the computer down when the format finishes. You will have to watch the progress, though, if you don't want the install to commence.
Boot disk option:
For XP, 95, 98, or ME, follow the instructions at this MS article page. It will walk you through creating a boot disk that will allow you to format.
You will need a floppy disk or CD
Apr 03, 2009 | Acer TravelMate 4200 Notebook
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
Ethernet controller for Acer Travelmate 2312
browse through the acer panam website in the drivers / service section...
Search Other TravelMate Models and Look For An Intel Chipset Driver, Download and install..
Feb 17, 2009 | Acer Computers & Internet
Acer TravelMate 2312
go to this site and select your location then download what ever drivers you need
http://global.acer.com/support/download.htm
good luck
Terry
Apr 01, 2008 | Acer TravelMate 2355LCi Notebook
Computers & Internet Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
