Question about NEC 80573 Corded Phone
Keeping Same Extension
I moved from another office. I want to keep my same extension. How do I do I change that on the phone. Right now I am having to use the extension that was assigned to the office I moved into.
Re: Keeping Same Extension
Well, from the master phone(usually ext 100). You need to make sure to press fea. 84 until it says "relocation ON". From there you type in 65*->then enter your ext.->then you will need the 10 digit password for the phone system. After that the ext. will be moved.
Posted on Nov 27, 2007
0 characters
3 Points
Our phones are avaya 2410 phones, I moved one user from one office to another, how can I have that users original extension follow to the new office.
You need to go into programming and move the 2 extensions in Manager.
Once moved in Manager, at each phone dial *36 to force the change.
Aug 23, 2012 | Avaya Definity 6408D Corded Phone
How do I have moved office and have connected my phone (panasonic kx-dt346) but I do not have an extension number, how do I program on in for my phone line? as no one can call me, but I can call out?
You have one, press the INFO button up to 3 times and your extension number will show on the display. A 6-line display phone is pretty unusual to be moving from one place to another as it's the control phone. If it was the only one in your system, MOVE IT BACK.
There is a manager's guide in the Operating Manual for your system that will give the instructions for changing extension numbers. It starts by going into manager programming (PROG **1234) and choosing program 004. In Panasonic land, you don't "swap" extenson numbers, you do a double change as in change 102 to 200 105 to 102 and 200 to 102.
Jul 04, 2011 | Panasonic KXDT346 Phone
How to move extension numbers from office to office using nortel t7316e
There is a feature built-in to the norstar system called "Set Relocation". When this feature is turned on, you can move a working extension to an unused/activated jack and the extension, features and mailbox will stay with the phone.
Have your system administrator turn the feature on, then move up to 2 phones at a time. The phone will go through 2 bootup sessions - be patient and don't unplug the phone.
Good Luck!
Aug 10, 2010 | Nortel T7316E 2-Line Corded Phone
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
We have an MLX-20L and I am trying to change entries as people have moved into different offices. It won't let me edit the entries.
You are just trying to change names?
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected. (Remove the plastic covers from the line and feature buttons, and remove the white labels. You will see the letters “A-F” on the display and the letters “G-Z” on the buttons. Enter the new name of the extension. See note below.)
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Mar 17, 2010 | Avaya Phones
Change Extensions on NEC IDK Phone?
It is easier to move the wires but if you know how to go into programming than change the extension numbers on the ports in mb 4-10
Apr 28, 2009 | NEC DTU 8D-2 Corded Phone
Change/reprogram extensions
The easiest way to do this is move the cross connect in the closet. Get the jack number from each location and swapped the cross connect(wire). You could change the extension number in MB4-10 but it depends on the type of system you have.
Nov 18, 2008 | NEC DTU 8-1 Corded Phone
Station (extension) names
From extension 10 or 11
Feature 00
Left intercom
Left intercom
Right intercom
enter the extension you want to modify
press the left intercom
Enter the name.
When finished, press feature 00 to exit programming.
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
Moved user, need to change extension at new desk for avaya 2420 phone
Have your system admin movethe extensions ports. You have a definity or S87xx series.....that is the only way.
Jun 13, 2008 | Avaya Definity 6408D Corded Phone
NEC 80573 Corded Phone Logo
318 people viewed this question
Top NEC Phones Experts
SC Spike
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you a NEC Phone Expert? Answer questions, earn points and help others
