Question about Photography
Hi my praktica mtl 50 slr as a loose fitment on the top were the flash gun slides in its the bit thats silver on top and black sloping plastic under it can i take the top of the camera of to re tighten it,are there any plans or instructions that show you how it comes appart,-regards-SB.
    Brigadier General:
  • 3,006 Answers
You can repair this by removing the camera top plate and re-fixing the hot shoe from beneath, but it's not without risk to your camera.
The MTL 50 has more electronics than the MTL-5 which it was based upon, and it's possible to damage them when you remove the top plate of the camera. If they are damaged they're still basic and usually easy to fix if you're familiar with basic electronics. Or if damaged you could revert to using a handheld light meter which you can pick up very cheaply as the electronics are only for metering purposes.
If you're not confident of the repair, then don't attempt it. You can get a separate flash bracket very cheaply which screws into the tripod hole and the flash can then connect to the pc socket on the lower right hand side of the lens mount as viewed from the front. This will also give better results as the flash is mounted off-axis just like professional photographers do. The flash bracket is not only the most conservative option, but it's the best one simply from a photo-taking perspective. Most of the kind of flash guns which fit your camera have a pc socket for off-camera use and usually come with a short lead for the job. If your flash gun doesn't have this facility then most used camera shops have loads of perfectly functional but utterly worthless basic units in the trash. (If you're in the UK I'll even send you one for just the postage costs, just add a comment to let me know and I'll be in touch).
If you want to go ahead you'll need to start by removing the film winding lever. The black disc on top of the lever unscrews with a reverse clockwise thread. Sometimes it will undo simply by pressing your thumb down on it and twisting clockwise whilst holding the lever from moving, but more often you'll need to press a pencil eraser firmly on to it and twist clockwise. Once the screw is off the lever should lift away.
Next, you need to remove the film rewind crank. Under the rewind lever is a screw and again this usually has to be turned clockwise to undo it. After removing the screw, the rewind crank lifts off.
Next, remove the two securing screws on the front of the top-plate and the two at the rear. It's been a while since I've done this so you might find there's also a screw at each end, they all undo anticlockwise as normal. Set the shutter speed dial and film speed to a convenient position which you're confident of being able to return it to, you may also want to put a bit of tape across the top to hold it where you've set it. The top of the camera should now come off, but be careful: there will be wires going up to the underside of the hotshoe and you don't want to strain or break them. You should be able to see how the hotshoe fixes to the camera and effect a repair. Try not to disturb anything else, but if you notice any gooey black foam then you need to decide whether to remove it. If you leave it then it's corrosive and will eventually damage at least the black paint on the pentaprism and spoil your viewfinder image, but if you remove it without knowing what you're doing then you'll damage your camera. If in doubt, leave it. Film SLR's and lenses are now ten a penny and folks are even giving them away so you may choose to use your camera until it breaks and then get another for peanuts.
Once you've completed your repair, reassembly is in the reverse order. Just be careful not to overtightebn the screws and you may want to apply a little liquid thread lock to them after cleaning the threads.
I hope this has helped and given you a few options, if so please return the favour by rating my answer.
Posted on Jul 14, 2009
  • Obertelli
    Obertelli Jul 17, 2009
    Now that I've checked my own MTL 50 there are a couple of corrections to what I've written above:-
    Film advance lever: the black disc on the MTL 50 pops off if you use a thin bladed screwdriver. Beneath it is a small circlip which you need to remove and then use a pin wrench to undo the securing screw which comes off anticlockwise. Basically the circlip is there to prevent the screw from loosening when you use the level.
    Film rewind lever: The MTL 50 does not have the screw I mentioned, instead you need to look up at the lever from beneath to see a hex fastener. Use a small spanner on the hex and grip the rewind lever button with soft jawed grips and unscrew clockwise. A scrap MTL 50 I've found unscrews anticlockwise but uses threadlocking compound to keep it secure so Practika clearly changed it during the production run.
    Both of my MTL 50's had the loose hotshoe and if you're careful you can glue it back on without dismantling the camera using a thin epoxy resin and a syringe. Superglue won't work as it won't hold the type of plastic (HDPE) which forms the base of the hotshoe. If you glue it I'd expect it to eventually fail again as HDPE is poor with most glues, but epoxy should last long enough unless you're a frequent strobe user.
Praktica 1600a
NO!!!!!
The flash's trigger voltage is much too high and will quickly fry the camera.
If you really want to use it, you need something like http://www.bhphotovideo.com/c/product/245292-REG/Wein_W990560_Safe_Sync_Hot_Shoe_to.html
to isolate the two units.
Jan 27, 2014 | Nikon Photography
How do I open up a rexel stapler?
There's a plastic button on the back of the Rexel stapler that says "press."
May 04, 2012 | Tools & Hardware - Others
Unlock issue
The black plastic just above the shoe- loosen it and the flash should slide off. It should loose in a counter clockwise direction as you look at the top of the camera
Feb 19, 2012 | Metz 58 AF2 Flash
My oki printer b430dn is flashing 380 paper jam but cannot see any paper, have removed toner and looked inside but still no joy
Hi
You have to look under the cover remove the black plastic cover, Remove in the left side by sliding the litte plastic tab in to the mittele and gently pull up, when it is loose in the left side slide it on to the mittle and it will go of in the right side too, Now remove the next black plastic cover, it's all black with at little "sharkfin" i the center, Just pull genltly upwards, and under there is the "380" It is at little tab, just wrikele it a few times. Now just assemble the printer an you are good to go
Oct 27, 2009 | Oki Electric Industry B430DN Laser 30PPM...
I have bought a tacwise 140EL nailer/stapler. I
Turn the gun upside down and pull out the black plastic loading thingy, drop the nails in the left hand side of the gun,press against side with finger and slide black loading bit back over top of nails-hey presto!
Oct 13, 2009 | Tools & Hardware - Others
Old Practica SLR camera shutter not working
I have a practica mtl 50 with a couple of extra telephoto lenses if interested.Very good working comdition.
bob
r_nichols@hotmail.co.uk
Sep 06, 2009 | Nikon F2AS Photomic 35mm SLR Camera
Does anyone know where the battery goes for the sylvania wireless mouse sy 037r??
The silver section next to the word Sylvania slides off. There is a release under the black curved under the word Sylvania. I used a flat head screw driver to gently slip between the silver plastic and black rubberized section and gently pressed down. It pops out. The small hole where the usb connector fits stays with the mouse and a small silver section slides off. For some reason I got it off once, and then it took a long time to find the release a second time. Good luck
Jun 04, 2009 | Sylvania Fellowes 9893501 Microban...
I cannot open my compaq evo d51s, any ideas?
I just removed one of these cases.
The silver face-plate is attached to the cover that you wish to remove. The black plastic just below the silver is a part of the base.
  • With the face of the computer towards you, place your thumbs on the black plastic below the face-plate.
  • Use your fingers to press into the side-buttons.
  • Using your thumbs to push against the base, pull the cover towards you.
Nov 20, 2008 | Compaq Evo D500 PC Desktop
Replacement shoe for Sigma EF-500
I had the same thing happen. Sent it into Sigma, they replaced it for 50 bucks.
Feb 03, 2008 | Cameras
Nikon f5
Just bought one of these for myself secondhand and had the same problem - there is a little bit of metal (2-3mm long) sticking out at the top right hand side where the film comes out of the cassette. I found you have to slide the film in from the bottom of the camera, so the leader goes over that bit and the round bit of the canister under it, then you push the bottom of the canister in.
Jan 31, 2008 | Nikon F5 35mm SLR Camera
Photography Logo
661 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
