Question about Kingston Kpex100 Digital Media Player
Audio only plays from left headphone
While walking through a crowded airplane, I snagged the headphones on a seat I was walking past. This yanked the headphones out of the Kpex's headphone jack. When I put the headphones back in, I discovered I could only hear sound in the left headphone, the right is completely silent.
I find that I *can* get audio out of both headphones by twisting the headphones plug in the jack, which leads me to think that there must be a contact inside the jack that is bent so it doesn't always make contact.
I have tested the same headphones on a different device and they work fine. Similarly, I have tested a different set of headphones on the same Kpex player and found the same problem.
I also dismantled the player in hopes that it was just a wire that could be re-soldered. No such luck, it looks like the jack is soldered in place properly, which must mean that the contact inside is bent like I suspect (I guess).
Does anyone know where I can purchase a new headphone jack? Is there another possible solution?
  • Anonymous Apr 04, 2008
    is hanging @ start up
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kingston Master
  • 1,001 Answers
  • Advanced Technology,The buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music .
  • Protect the earbuds when you during runing and workuots have sweat.Compatible with iPhone 6/6s,6 Plus/6s plus, 5 5c 5s 4s,iPad Air, Samsung Galaxy S6,S5,S4,S3 Note 4 3, HTC M9 M8 M7, LG Flex 2 G3 G2, and Other Bluetooth Android IOS Smart Cell phones/Devices
Amazon com Bluetooth Headphone Charm sonic for Gym Runing Exercise Sports...
Posted on Jan 03, 2017
    Problem Solver:
  • 5 Answers
Try to change your baby jack adapter inside your kpex,because it was damage,if it is still under the warranty,bring it to your kpex dealer
Posted on Feb 16, 2008
  • 37 Answers
The contacts inside the headphone jack are made of a springy metal there is one for the left and one for the right speakers. This happened to my Blackberry and I took it apart and got inside the jack block and re-sprung the contacts. It worked for me... I used a dental pick.
Posted on Nov 09, 2007
The cord got yanked and now my headphones dont portray any sound
try wiggling the cord as you play a constant sound through it. It is quite possible and probable that the cable inside the headphone got disconnected entirely (the copper wiring)
Jan 31, 2014 | Audio Players & Recorders
Left Ear cup not working.
Either ship them back to manufacturer if still under waranty or you'll have to re-solder the wiring to that speaker if they have become disconnected or yanked accidentally of which the leftside is usually where the headphone cable first enters in the left side.
Oct 10, 2013 | Audio Technica ATH-ANC27 Headphones
No sound coming from iFrogz cs40 headphones Comfort series
No sound from yanked headphones:
Most likely cause is the litz wire has broken off internally from the loudspeaker of the corded entry side.
[1]: Remove ear cushions
[2]: Separate speaker-plate from headphone housing
[3]: Re-solder wire to speaker solder-tab.
The "Litz" wire may have broken behind its solderable bare copper part, in which case you mast clean the end before re-soldering.
The shellac varnish insulation can be scraped off a few mm with a craft knife, or flash-burnt with a flame.
If flash-burning, use pliers or dampened fingers to mask wire as varnish can flash back entire length.
Quite often, the leads are too short once broken, if manufacturer left little slack.
If this is the case, solder and insulate a short length of stranded intercom wire to extend the Litz.
Jan 17, 2018 | ifrogz EarPollution CS40 Headphones
Both sides of my headphones are outputting sound however music that is supposed to be left isn't outputted at all. That is, if a song has instruments playing on the left side of the track, it won&
Are you using the 1/4 inch adapter- if so- make sure the mini plug is fully seated- you should feel 2 detents as you push the plug into the adapter- if you do not, you may be bridging the tip and ring colar with one channel and because it is not seated fully, it is not contacting the other channel at all.
Also make sure the plug for the headphones is fully seated into whatever device you are listening to. you should feel the 2 detents each time.
Apr 01, 2012 | Music
My earphones have stopped playing music. It just started in the left ear, now it doesnt play in either. Can this be fixed?
try using other headphones to your unit, if it plays, the problem is in the CX400 indeed. usually caused by unintentional yanking & other factors, the internal of the wires were broken, it can be fixed yes, with patience and some soldering skills, just find the appropriate cable for that particular model, with imagination you can even use other headphone cables, ;-)
Feb 03, 2011 | Sennheiser CX 400 Headphones
I have a garmin nuvi 360. It has an audio problem. It usually doesn't play any audio unless I plug in headphones or an audio cable. And when I plug in the headphones it only plays through one ear. But if I...
Please see this link:
http://www.sharc.net/gps_audio_repair.htm
Your headphone jack connections have broken inside, cutting off the speaker and one side od the audio, left or right. The jack needs to be replaced or resoldered.
- Jim
Jun 30, 2010 | Garmin Nuvi 660 GPS Receiver
The left side wont play music but the right side will play it completely
hi there, I had skull candy earbuds in the past. The problem is that the left side has a short in the speaker. It means that you need to get a new pair of earbuds as they are not fixable.
Mar 02, 2010 | Skull Candy Smokin' Buds Headphones
I have a casio keyboard and if i plug headphones into the audio hole they dont work it just plays out loud. help.
It is important that your headphones are STEREO tyoe as a monaural 1/4 inch plug will short out one side of the output audio.
Make sure the plug is fully seated as it has a switch in the unit that disconnects the speakers typically when headphones are plugged in.
If your speakers do not get cut off when you plug in the headphones, it is POSSIBLLE that the switches on the jack have been broken. This would require servicing.
Dec 28, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Left ear no music
Before you worry about repair, verify that the balance control in the iPod isn't causing the problem. The easy way to do this is to try some other audio device (home stereo, etc).
Mar 19, 2009 | Coby CV-190 Consumer Headphones
Kingston Kpex100 Digital Media Player Logo
332 people viewed this question
Top Kingston Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kingston Audio Player and Recorder Expert? Answer questions, earn points and help others
