Question about Epson Stylus CX9400Fax InkJet Photo Printer
Epson CX9400FAX guzzles color ink
My Epson CX9400FAX goes through color ink like crazy. Its only 8 months old. I now average printing 20 to 40 copies a week from my home office. My color/B&W printing ratio is 1/20. I know it still uses color ink for B&W, but the epson cartridges purchased less than a month ago are more than half empty. Epson Support offered no solution.
  • Dano853 Jul 02, 2009
    If you are going to call yourself an expert then you should at least know that the question posted asks about an EPSON printer, not an HP as you called it. Also, Epson printers have 3 individual color cartidges and 1 black. Care to take another shot at it?
    Maybe I need to be more specific. I have twice replaced the 3 color cartidges in the last 4 months. With no error messages and no other problems with the printer, the color ink is getting used way to fast for the amount of printing done. Is the EPSON STYLUS line known for high color ink usage? Is there a way for me to check to see if I have alot of ink being wasted when the nozzles charge or clean? Nozzle cleaning and test page printing have shown no indication of a problewm, what it could be, or how to fix it.
  • 10,515 Answers
Hi Dano853,
How are you?
Have you ever read the reviews before purchasing Epson? Believe me Canon is much better than Epson. They go guzzle color ink like Kool Ade, although very high in Quality.
Read a review regarding Epson products :-
http://theunloadingzone.blogspot.com/2007/09/epson-cx6000-guzzles-ink-and-now-blocks.html
It's an example. We can work to minimize it's WASTAGE. However, to expect it to use toner like Canon, Hp - It's near to impossible.
Use the trial Verison to calculate Ink and Toner Coverage calculator :-
http://avpsoft.com/products/apfill/
You can use 30 days trial to see exactly how your problem can be minimized.
There are different ways to minimize usage ( General ) :-
As the costs of just about everything continue to go up, spending on items that we might call luxury items goes down. You may not have thought about it before, but printer ink can be one of those luxuries when you’re considering whether to buy a half a tank of gas or a new set of printer ink cartridges. To forestall the purchase of those $30 black ink cartridges or $60 color/black packages there are some easy printing habit changes you can make.
Keep your nozzles clean
Perhaps the easiest change you can make to your printing habits is to keep an eye on your printer heads. The printer ink nozzles that dispense the actual ink use a spray function to get the ink onto the paper. As such, these nozzles can find build-up occuring. If the ink collects on the dispensing head excessively more ink will likely build-up on the head then the paper
Print only what you need
When it comes to printing, most people are fairly lazy. Click on the print icon and you’re done. This habit lends itself to several habits changes that you can make to significantly reduce your printer ink usage but also your paper usage. Instead of just hitting print, add the print preview function to see what you are about to print. Then ask yourself; do I need all those color ads on the sides? Do I need the last two paragraphs on the page? If not, consider turning off the color ink cartridges, select only the text you require and select only the pages you need –especially that last page with the footer that comes out with each print job.
Alternate colors and reduce size
Maybe this thought is going to the extreme but it will extend the overall replacement cycle of your ink cartridges. Print in different colors on a rotating basis. It may be a bit hard on the eyes but printing only in green or blue to spread the color cartridges use out over time is a way to better balance your overall cartridge use. Also on the bit excessive side, is reducing the font size on the documents you are printing.
Print only when needed
Keeping a leash on your clicking finger is perhaps the best ink saving tip that could be given. The tendency is to let your hand and finger head right for the print function as a matter of course. Stop and think about it for a few moments. Will that that piece of information be used somewhere else where I’ll need to reference it often? If not, try minimizing it for five or ten minutes. If you keep coming back to maximize it you can likely print it because it is relevant.
Hope i helped.
DO RATE THE SOLUTION.
Thanks for using "Fixya".
Posted on Jul 02, 2009
    President:
  • 1,383 Answers
I think your new hp clour ink cartrdge has problem.
Change new ink colour cartrdge when it is empty .
Also check both ink cartrdge level also it should be at same level both level of colour and black /wh.
Epson xp-300 less then 6 months old. I ran out of black ink so i replaced it with genuine epson cartridge now it prints a purple hue across the entire page when doing a copy but printing from computer its...
When you say copy, I assume you mean scan copy. Check your scan settings. Change it to DPI of 75 and monochrome. See if the purple is present. Also make sure the contrast is set to default.
What I dislike is sometimes manufacturers use color ink when you want to print black. It causes you to replace your color more often. To me it is dishonest. Anyway, try the scan settings.
Nov 16, 2013 | Office Equipment & Supplies
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My printer refuses to let me print when one ink color is gone
No, the CX9400 cannot be used if a cartridge is empty or missing and cannot be overridden.
Apr 08, 2010 | Epson Stylus CX9400 Photo Printer
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
Epson stylus cx9400fax; only the black wont print corrct, gaps, missing, illegible. all other colors work fine, have done nozzle check, head cleaning, and replace cartridge. can I take this thing apart and...
You may need to replace the inkpad, it is located under the cardrige park. Also clean the rubber sqeegee blade.
Wear cloves and use a tweezers to remove the ink pad, new ink pads are available online and thru the reatiler that sold you your printer.
Mar 11, 2010 | Epson Stylus CX9400Fax InkJet Photo...
Black ink dosen't print color does
Most likely your black ink is out and will need to be replaced.
Nov 10, 2009 | Epson Stylus CX9400Fax InkJet Photo...
I have inherited an Epson R1800 printer that guzzles magenta and cyan inks like crazy. Am I doing something wrong?
No, If you are printing any coloured output this will be normal depending on the actual colour content and what most people don't realise is that unless your text is pure black then it will be printed using the color carts as well and not the black ink cart.
Oct 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
Change ink cartridges and now the printer is not working, can't print any document from computer. What should I do to get the printer to print?
Cartridges may not be installed properly. Remove and reinstall, listen to the click for each one. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 28, 2009 | Epson Stylus CX9400Fax InkJet Photo...
When I print or copy there are missing lines of print.
Hi, one or two head cleans won't clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Epson recommends printing a colorful document at least once a month to prevent nozzles getting clogged, see the Epson online guide:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cwxY9S6wZhcOql4VsOeN1ay&tc=5#10
Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 30, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson DX4000 printer
Hi..
Try this. Removed the color cartridge. Open the printer settings under Quality and check the box that says print in "greyscale" or "black and white.
This will rule out and color cart problem and also change the printer settings. You will have to change this back to print in Color,
Hope this helped........
Squipps
Feb 06, 2008 | Office Equipment & Supplies
Epson Stylus CX9400Fax InkJet Photo Printer Logo
82 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
