Question about Refrigerators
Bosch KSU 40 fridge leaks water - Refrigerators
I found that the entire defrost system had frozen over. to check the fridge for this problem you will need to:
pull out fridge, turn off power, remove cord (whilst at the back check the grills are clean, all dust in the cavity of the house and the condensor is clean and ensure that the 'travel wedge' has been removed from the engine.
remove food and shelves from freezer compartment.
with small (2.5mm wide) standard pop the three white screw covers up from the bottom tray. Undo the 2 philips head screws (with a 2 point screwdriver) Pull tray out. Lot of ice underneath? It's frozen over! you're going deeper!
Remove centre tower by squeezing the sides at the base near the rear wall. remove.
Chisel ice and remove, pour a little hot water down the two funnels at the rear.
To examine how fair the problem is and to let air to circulate you can remove the rear wall and polysterene insulation by removing the panel in the left upper portion with the 2.5mm screwdriver and removing the red, far right socket (this is the fan's point). Use 2 point and remove the 2 screws on the rear wall and remove, remove insulation. You're in.
Let completely defrost, clean up and dry all water and re-install.
Posted on Aug 28, 2009
    Genius:
  • 1,239 Answers
Hi sir/.madam
first check the outlet valve and water pump,,,
these both are common problems...please check it//////
thank u,,,/please rate it
Posted on Jul 02, 2009
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Posted on Feb 07, 2009
  • 22 Answers
SOURCE: bosch fridge leaking water
ok seems here that u have a defrost problem or a buggered evap fan motor ie is there breeze flowing from the cover at the back of the freezer if yes than this fridge has not got a manual defrost control it has an electronic timer built into the main pc board witch means that it could be the defrost element itself or the main pc board is gone looks like u will need to consult a professional to resolve this problem taking into account that there is at least some water dripping into the drip trey at the rear of the fridge at the bottom on top of the compressor if not than it could be a blocked drain
Posted on Sep 10, 2010
Fridge makes a rattling sound every 5 mins or so. It's a Bosch Ksu 45621au/02. Fd8706
Could be associated with ice being delivered to the drawer as it is made... Or... Motor not mounted tightly, something against it, foreign objects sitting against fridge.
Oct 08, 2013 | Refrigerators
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
I have a bosch fridge /freezer ksu 44 and there has been crackling sounds coming out of it and now it seems its freezing in the fridge part as well. There was water on the bottom tray which i cleaned every...
try this first :
turn your thermostat down first until the fridge stops .
turn the thermostat back up only a quater of the way and wait to see if the fridge turns on and off as usual .
if it does , the thermostat is ok .
if it does not , i believe the thermostat is dead .
in regards to the ice in the fridge part , you maybe have the fridge turned to far up but let me know how you go .
Sep 29, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Feb 10, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Bosch fridge KSU 44 leaking water from bottom of fridge
Feb 07, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Jul 27, 2008 | Bosch Refrigerators
Leaking door on front loader bosch washer
Make sure latch mechanism is tight and check out the seal for imperfectionc ....ie cracks or flat spots
Jul 22, 2017 | Bosch Washing Machines
Refrigerators Logo
1,043 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
