WHEN PRINTING DUPLEX THE LOWER LEFT CORNOR OF THE PAPER IS SCUFFED AND WRINKLED AT THE EDGE. LARRY O'HERN 480-837-2180]] LOHERN@COX.NET
  • 528 Answers
This usually happens if the printer gets too hot.
Try following steps.
1. Keep the printer in a well ventilated area. 2. Switch off the printer, let it cool for at least fifteen minutes. Switch it on and start printing. 3. Check the printer settings. Make sure the paper size and paper type matches exactly with the papers you are using. 4. Use a slightly thicker paper (with higher GSM). You will have to change printer setting accordingly. 5. Clean the paper feeds in the tray.
Try these steps and let us know.
Posted on Jul 02, 2009
I have a hpj6480 printer. It says paper jam. I've done everything, turned off removed every piece to clean out, pushed every imaginable button...still paper jam it reads....
Below are the causes of paper jam
  • Paper loaded incorrectly in the paper tray.
  • Damaged or dirty paper rollers.
  • Torn, wrinkled, or damp paper loaded in the paper tray.
  • The rear access door or two-sided printing accessory (duplexer) might not be closed or is not locked into place.
  • Paper was added to a stack already in the tray while the HP product was printing.
  • The tray contains more than one type of paper.
  • The paper is jammed inside the HP product where you cannot see it.
  • An obstruction is blocking the paper path.
  • Torn pieces of paper from a previous jam are stuck in the product.
  • The tray is too full.
  • If printing on an envelope, the edges of the envelope are bent.
Try steps provided in below link and check if paper jam is resolved.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01312792
GuruAid.com
Oct 30, 2014 | Office Equipment & Supplies
When print 13.10.00 error appear
Welcome to fixya,
13.10.00 jam inside lower left door or 13.10.00 jam inside duplexer Description A media jam has occurred in the duplexer area of the printer. Action
  1. Check for stuck media in the paper path around the fuser and duplexer area. (See the paper jam locations in the printer section for further assistance).
  2. Make sure hat the lower left door closes properly.
  3. If this message persists, contact an HP-authorized service or support provider. Click here to go to "Handling persistent messages?? above.
Hope this helps.
Dec 19, 2010 | HP Hewlett Packard LaserJet 5200 Printer
Says paper jam and there isnt!
It is possible that even though there are no full sheets of paper jamming the printer that some torn bits have been left behind. You need to make sure that cleaning is complete.
Visit this site for full details:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00212225&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&product=422000&key=null
Preventing paper jams The following recommendations can help prevent recurring paper jams in your HP product.
  • Before loading paper in the tray, hold the stack of paper, and then tap the bottom edge on a flat surface so that the stack is even on all sides.
  • Make sure that the length and width adjusters on the tray are correctly positioned, and then push the stack of paper forward until it stops in the tray. CAUTION: Do not force the paper to move too far forward in the tray.
  • Do not overload the tray with paper.
  • Only add paper to the tray when the product is not printing.
  • Make sure the HP product supports the paper type. See the documentation that came with the HP product for more information.
  • Do not print on paper with paper clips or staples attached.
  • Do not use paper that is bent, torn, dusty, damp, wrinkled, curled, or paper that does not lie flat.
  • Use only one type of paper at a time. Do not mix different types, weights, or sizes of paper.
  • Do not use paper that is too thin, too thick, or too glossy for the product.
Cause The following factors can cause paper jams:
I hope thihs is helpful.
Dec 08, 2010 | HP PSC 2355 All-In-One InkJet Printer
How do I print on both sides of the sheet?
If you print to an IS networked printer the printer will automatically print on both sides of the paper (duplex). This saves paper but, because it is print toner which is the largest part of the cost, charges are the same as printing on two sheets of paper.
If you wish to print duplex to another printer (NB not all printers support duplex printing) you must:
Office 2007
  • Open your Office Document
  • Click on the Office button in the top left corner of the screen officebutton.gif
  • Click Print and select one of the printers that will perform duplex printing
  • Click on the Properties button under the Layout tab
  • Choose either Flip on Long Edge or Flip on Short Edge and click on OK If your page is set up as Portrait
  • Choose Long Edge If your page is set up as Landscape
  • Choose Short Edge . Click on OK again to send your work to the printer
Other Applications
  • Go to File and Print
  • Select one of the printers that will perform duplex printing
  • Choose Long Edge if your page is set up as Landscape
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Paper not feeding properly
Follow these steps to reload paper:
  1. Remove the paper and make sure it's not curled or wrinkled.
  2. Fan the stack to make sure the sheets are separated.
  3. Open the paper support and pull up the extension.
  4. Extend the output tray.
  5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
  6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
    You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
  7. Slide the edge guide to the edge of the paper, but not too tightly.
    Follow these guidelines when loading paper:
    • Do not load paper above the arrow on the edge guide.
    • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
    • If you're printing on both sides of the paper, try loading fewer sheets.
    • If it's wrinkled when it ejects, the paper may be damp or too thin.
    • Do not load paper with holes punched in it for insertion in a binder.
    • Load the printable side face-up. It's often brighter or whiter than the other side.
    • Load letterhead or preprinted paper top edge first.
    • If you experience paper feeding problems, try loading fewer sheets.
    • If you're using special paper, check the package for special loading instructions.
Follow these steps to reload paper in the Automatic Document Feeder:
  2. Tap the originals on a flat surface to even the edges.
  3. Move the edge guides outward.
  4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
  5. Slide the edge guides against the originals.
Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
Each time I print on plain paper the paper feeds into the machine and when it hits pinch rollers after the print head, the top right hand corner is turned over. Two pages later and the third page is so...
  1. Flip the feeder guard forward.
  2. Remove the paper and make sure it's not curled or wrinkled.
  3. Fan the stack of paper to make sure the sheets are separated.
  4. Reload the paper against the right edge of the sheet feeder andslide the left edge guide against the other side, but not too tightly.
  5. Don't load paper above the arrow mark on the left edge guide.
  6. Make sure the printable side of the paper is facing up.
  7. Flip the feeder guard back.
  8. Once you have completed the steps above, press the cp_button_6.gif Start button.
Mar 07, 2009 | Office Equipment & Supplies
Left corner of paper wrinkles when printing
I know several reasons, and they are all related to an obstruction of some sort..whether it be a small piece of paper along the paper path, to something slightly bent, or broken...impossible to say for sure
Feb 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
P3005n prints one sided fine, but jams in fuser on duplex
Lower the rear door ALL THE WAY DOWN past the 2 stops
Remove the 2 screws, pull off rear cover
Remove the small left rear cover and small right cover
Unplug the 2 small plugs on the right side.
Remove wires from white clip.
Remove large white plug on big circuit board
Remove 2 screws and pull out fuser
Look for a switch knocked off
Feb 13, 2009 | HP LaserJet P3005n Printer
Xerox Tektronix Phaser 7700 Laser - Wrinkling paper slightly.
Hy the problem is: You have to clean the 2nd BTR and the transfer belt cleaner. There is a large amount of used toner on those things.
Oct 30, 2008 | Xerox Phaser 7700 Laser Printer
93 people viewed this question
k24674
jasbo
jasbo
