Question about Toshiba 50HM67 50" HDTV
My toshiba 50HN67 TV won't power on.
My toshiba 50HN67 DLP TV won't power on. The yellow light blinks regularly - this is NOT listed in the manual (yellow blink + blue solid means lamp out; nothing listed for yellow blinkalone). The TV is two years old, and I replaced the lamp 6 months ago. I pulled the lamp and inspected it just be sure and it appears to be OK.
Can anyone help? Thanks.
  • monktrane99 Jul 07, 2009
    not sure, is not at the house right now. my recollection is that it would blink several times, say 3-5 times, then pause, then start the same cycle again. It would do this non-stop as long as it was plugged in.
  • monktrane99 Aug 22, 2009
    thanks for the reply. I tried that a number of times - didn't work. finally had an "authorized" Toshiba repair man come, charged me $100 for a diagnosis of "not sure exactly, but probably the ballast, $500". After much unsuccessful haranguing w/ repair man and corporate toshiba, I threw in the towel. Sold the tv "as is" to repairman for $100 (it would have needed a new bulb, $150 in about 3 months anyway). Bought a new Panasonic 50" plasma for $800. MUCH better picture, hopefully more reliable. Wouldn't go near either DLP or Toshiba again.
    Problem Solver:
  • 18 Answers
I have the same TV and had the same problems. What worked for me. I tuned off the set unbluged the TV, waited about five minutes and replugged and resolved my problem. Hope this works for you.
Posted on Aug 22, 2009
    Genius:
  • 1,239 Answers
Hi
can u tell how much times the light blinks..
then i can give solution...
thank u,,,///please rate it
Posted on Jul 02, 2009
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
We have a toshiba 72 dlp tv. We were in the living room in which tv is in we heard a pop. When we went to turn the tv on we heard sound but no picture and the yellow light on the front of the tv blinks 16...
Good day!!!
Your color wheel is clapped out. The part is not directly replaceable - they seal it in the light engine and won't sell spares. A rebuilt engine for this set will probably run you between 230 and 270 USD. Replacing it is a cinch if you can get another engine for it.
Jul 16, 2011 | Televison & Video
The power light blinks 3 times. What does this mean?
Toshiba Flat Panel Television how-to instructions, help and tips Three times so far, just the tv not the cable. Toshiba Flat Panel .... Timer light blinking red. TV will not turn on by power button on TV or using the ...
tv.manualsonline.com/.../toshiba/.../flat_panel.../product_problem toshiba.justanswer.com
Mar 11, 2011 | Toshiba Televison & Video
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 50HM67 50" HDTV Logo
970 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
