Question about Whirlpool Washing Machines
My washer wont spin keeps sayin CLEAN PUMP????? not sure how to do this HELP
    Problem Solver:
  • 9 Answers
You may have a hair pin, coin or sock in the pump that has blocked the pump or maybe keeping your pump from turning properly. I recommend getting a tech to fix this.
Posted on Jul 02, 2009
Keeps coming up with f5 wont pump out or spin
You need to chjeck and clean the pump filter.
Remove rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Nov 29, 2010 | Hotpoint Aquarius WD640 Front Load...
Hi got hotpoint aquarious wmf740. all lights flashing f-05 ? wont spin or drain. please help
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer.
Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps...
Daniel
Aug 30, 2010 | Washing Machines
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
My washer gets so far then says fp
fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
LOCKED UP AND WONT SPIN
POSSIBLE PUMP PROBLEM, REMOVE 3 SCREWS 7MM FRONT BOTTOM PANEL CLEAN OUT PUMP WHITE PLASTIC ,, THATS IT CLOSE IT BACK UP ...
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
Front load washer wont spin
it must drain before it will spin.if water is standing in it .remove power take off frount panel.remove screws that keep pump onthe washer move towards bucket and open pump and clean out.God bless tom
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My MayTag performa oversized capacity washer wont spin
Usually this is caused by the pump being cloged or broken. Remove the pump and clean the pump out. Make sure it spins freely by hand.
Nov 20, 2008 | Washing Machines
Washer doesn't drain or spin
remove bottom panel dip as much water as possible out if possible lean washer backward to keep as much as possible away from pump inlet remove clean out port plug by turning counterclockwise clean debris from pump impeller
Jun 05, 2008 | Kenmore Elite 45986 Front Load Washer
Front load washer
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Apr 20, 2008 | Washing Machines
Washing Machines Logo
91 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
