Question about Linksys Wireless-G WRTP54G Router
Cannot connect to router signal on computer keeps going off then on??
  • 60 Answers
How far away is the computer? this usually happens when the signal is weak and the computer has trouble keeping connected, try moving the devices closer together, failing that do your windows updates as the newer updates improve wireless capabilities.
Posted on Jul 02, 2009
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Computer keeps dropping signal and now doesnt recognize signal
how far is your computer to the DSL wireless router? If it is too far and signal becomes to weak you won't be able to connect. And also make sure that there is no metal, concrete wall in between, it will block signal too. Good luck Thanks
Aug 15, 2011 | Linksys WRT160N Wireless Router
My belkin wont keep connection
1. Powercycle your equipment (unplug the power to your router and your modem)
2. Wait 15 seconds then plug equipment back in.
3.If your Modem runs off signal from a tower try and get more signal simply by moving modem closer to a window.
4.Check your connections to the modem and to the router, ensure the wires are plugged all the way in.
5.Using your wireless signal from your computer pc or laptop ensure you have sufficient signal you may have to move closer to the router, once in a while you will be to far from your router to have a good connection.
6. Make sure the ventilation slots on modem and router are not blocked.
7.Check to see how far your modem is away from any electrical equipment your modem should be away at least 3 feet away.
8. If you are able to keep connection directly plugged into your modem from your computer most likely there is an issue with the router, In this case you can always reset your router there may be a configuration error in your router, To reset simply press and hold reset button on the back of the router for approximately 15 seconds or until router restarts, Caution by resetting your router will reset back to factory default and your router will be unsecure once again.
9. When your are disconnected from the internet make sure that the Connection itself isnt still connected if your connection itself is connected and you are unable to get online you may need to renew your ip address. usually your ip address automatically renew's once the router and modem have been powercycled (unplugged and plugged back in) however you may need to manually renew your ip.
10.Windows Xp: Start/Run/CMD and press ok
A.Type ipconfig /release
B.Type ipconfig /renew
Windows Vista/7 Start/All Programs/Accessories/Right click on command prompt and hit run as administrator.
B.Type ipconfig /renew then restart your computer
If you are a Mac user:Here is a link to show you how to renew http://support.apple.com/kb/TS1920 If your continue to get disconnected contact your ISP (Internet Service Provider) Check and ensure that it is not an issue on there end
Nov 15, 2010 | Belkin (F5D5231-4) Router
I just starting using this wireless router and when I set it up the router software keeps saying I don't have a connection to the internet but I'm on the internet on that computer right now. ...
Make sure that there is not direct connection between your desktop and modem ( USB ). If there is any USB connection from the modem to the computer then it will go on linee but the router will not be on line.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Apr 30, 2010 | Linksys Wireless-G WRT54G Router
ADAPTER not working
Check the distance bet computer and the Router.
Donot keep your router near television, microwaveoven or any radio active devces, it may reduce the performance.
Check the Antena terminals for any loose connections.
If possible check your wireless signal strength with another Laptop, to diagnose the router is working fine.
If everything seems to be fine, it maybe the issue with the Adapter.
Goog Luck
Feb 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
Oct 06, 2009 | HP (319468-002) (319468002) 802.11b...
Laptop keeps disconecting from belkin54g dsl network (home)
Wireless connections are best when distances are short and there are no brick or thick walls interfering with the signal between the router and your laptop. Try the following test:
Start using the laptop from an open location that is close to the router. Monitor the signal strength as you walk away from the router. Go into other rooms, go upstairs, downstairs, etc, and you will most likely notice differences in signal strength depending on where you are, or how far you move. Of course, you will suffer frequent disconnections when the signal is at its weakest point, no matter what equipment you use, be it new or used.
Try locating the router in a way that your signal strength is strongest, without affecting the other computers. It's a trial and error thing.
One last thing you could do is to go to your wireless adaptor configuration settings and set the Roaming capability to agressive, and set the connectivity to distance, for higher performance.
Aug 19, 2009 | HP Pavilion dv4000 Notebook
Why does the linksys wireless router ''WirelessG: keep going off/
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 05, 2009 | Computers & Internet
The actiontec gt704wg works fine
  2. Wireless settings of the router are still set to default.
  • Placement of the router: place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
Change your SSID and encrypt with WEP or WPA security.
Thanks, Joe
Jan 04, 2009 | Actiontec GT704WG Wireless Router...
Linksys Wireless-G WRTP54G Router Logo
54 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
