Question about Hilti TE 7-C 120V Rotary Hammer Drill
Hilti 76 p atc
I have a hammer drill 76 ps atc, and I would like to know what the problem that the light of service remains turned and the hammer doesn't work
  • rino_cacciat Jul 05, 2009
    I have changed the brushes and the complete service, but the light remaining turned on and he doesn't work
    Sniper:
  • 61 Answers
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
Posted on Oct 11, 2009
  • 2,176 Answers
The light remaining on means that the tool needs serviced. I would check the brushes first for wear and if worn excessively it needs to be sent for service ( brushes, o rings and lube) If not bad the switch could be bad and the service light needs to be reset. Let me know and I will try and help
Posted on Jul 02, 2009
  • David Ford
    David Ford Sep 09, 2009
    found your reply sorry for the delay new to system, but if still having trouble what you need to do is remove the handle assembly from the body of the tool it will unplug from the tool and then plug cord in to a live outlet and pull the trigger and hold while unplugging reassemble and the light should go out if any problems let me know and I will try and keep on top of it.
  • PJ03 Jun 29, 2014
    I have the same issue, tried your fix but no luck, checked the brushes, one has a few chips out of it but does not look worn down...could these missing chips be my problem?
How to reset service light on hilti te 76 atc??
Only factory service can reset certain faults.
Test kit is available to run drill without electronics.
Sep 17, 2012 | Drills
How to reset te76 atc module
Eto rabotaet. Spasibo!
Its working. Thanks!
Apr 07, 2012 | Hilti TE 70 Hammer Drill Performance...
What does the p stand for on a hilti te-76 p atc
That means it has available Hilti's theft protections system. You can purchase a electronic key that when you swipe it over the tool it programs itself to that tool. After the tool is unplugged for 20 minutes after it is programmed it will not run again until you swipe the tool with the key.
Jun 22, 2011 | Hilti Drills
My. Hilti 76 atc. Shows service light. Changed. Carbons still. Light on. And won't. Work
the light needs to be reset and usually you have to send to Hilti for them to do it. BUT if you are mechanically inclined I can try and help. Send me a reply before I go into detail about how to try this, it will require you removing the handle assembly. Let me know
Jun 12, 2011 | Hilti Drills
Bought hilti te 76 atc combi hammer breaker from ebay,it came friday and ive tryed to use but it wont except my sds max bits,seems like it carnt get past the two balls insde the shaft of thr chuck ,thanks
try turning the bit by hand a little while just pushing the bit in. On those you don't use the collar to install. You also might want to try and putting a SMALL amount of grease on the shank and retrying. Let me know if you still need help
May 15, 2011 | Drills
I am looking for the trigger switch for a Hilti TE 76 ATC rotary hammer
go to Hilti.com and you can buy direct, they also have a locator so you might be able to find it faster. You can also call them at 1-800-879-8000 for assistance and to place an order. Let me know if you need more assistance.
Mar 22, 2011 | Hilti Drills
How to reset Active Torque Control in the handle of Hilti model TE76P-ATC Rotary Hammer Drill
Active Torque Control (only TE 76-ATC / TE 76P-ATC)
The TE76-ATC / TE 76P-ATC is equipped with the Active
Torque Control system in addition to the mechanical
torque limiting clutch. This system offers additional protection
while drilling by rapid shutdown upon uncontrolled
rotation in the axis of the drill bit, e. g. when the
drill bit jams due to hitting rebar or when the insert tool
is tilted unintentionally.
When the ATC system has become activated, the tool
can be restarted by releasing the control switch and reengaging
it after the the motor has stopped rotating
("click"-sound signals readiness for use).
Always choose a working position in which the electric
tool is free to rotate in a counter-clockwise direction
(as seen by the operator). If this is not possible, the ATC
system cannot react.
Mar 01, 2011 | Hilti Drills
Parts for my hilti te 76
Call 1-800-879-8000 or go to Hilti.com for a schematic or call for assistance.
Sep 22, 2009 | Hilti Drills
Service light
You can reset the light. What you need to do it remove the handle assembly from body of tool. The contacts will unplug. Then plug the cord in and pull the trigger and sometimes the light will blink, while holding the trigger in the on position unplug the cord. reinstall the handle and the light should go out. Sometimes you have to pull the trigger while plugging cord in but this should work. and then while holding unplug cord.
Sep 21, 2009 | Hilti Drills
Hilti TE 7-C 120V Rotary Hammer Drill Logo
3,079 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
