Question about HP GbE2c Layer2/3 Ethernet Blade Switch for c-Class BladeSystem - Switch - 16 ports - EN, Fast EN, G...
Usb ports (HP Pavilion dv2000 Laptop) unable to retreive data
I've a laptop (HP pavilion dv2000). All the 3 usb ports, while loading a pen drive or hard disk thru' usb, it doesn't automatically open the H drive. Instead it asks for the formatting & even when i say yes to the command for quick formatting, it shows its disability to format. Although my USB data card & printer thru' usb are functioning correctly. Pls. help, its urgent.
  • HP Master
  • 2,258 Answers
NO OS STATE is this the XP virus maget , dead for 3 years now?
XP does not work on many USB devices even after the SP3 update
and THE SP3 UPDATE is mandatory. service pack 3
DV2000
id bet you if you booted to linux CD, (knoppix 7 live)
all usb ports work, telling you what, in seconds, XP IS DEAD.
for a fact.
google XP USB dead, (billions of hits for 16 long years)
MS dont support this OS nor VISTA or older.
HP does not support DV200o now its legacy hardware now.
MS plug and play is dead too on XP. per there warnings.
The means all new XP things will be dead, if the maker of said things
does not give you Their soft or that thing..
if hell bent on using XP ,(why) upgrade to W7
then get SP3 there.
https://www.microsoft.com/en-us/download/details.aspx?id=55245
it came new with XP
and was VISTA READY, best is to go W7. !
Goodwill store has $20 laptops with W7 on it working now.
why wait, dump yours, and UPGRADE HW/SW all at once
and WIN.
why to not RUN XP (endless bad and advancing....)
http://www.pcdied.com/XP-sux-sg.html
Posted on Aug 02, 2017
ted1430
  • 339 Answers
SOURCE: 3 vlans, data,1; data 2,;voip,5. Ports carry voice
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Posted on Aug 08, 2009
johnychel
  • 796 Answers
SOURCE: Hp pavilion dv1000. All 3 USB ports not recognising any device
go to device manager and from there try updating the usb drive from there
Posted on Feb 28, 2008
kyo_ajis
  • 68 Answers
SOURCE: New laptop... HP Pavilion dv2000 DVD drive does not recognize any disk
i hope the size of file not larger then then the DVD/CD, ( i think you already know about that)
if you burn multiple format of file, make a folder and put all the file in the folder, so burn the folder,
especially when you put a zip folder, sometimes it will cause error,
Posted on Jan 28, 2009
shredivya
  • 71 Answers
SOURCE: USB ports on my laptop not connecting
You can try uninstalling USB root hubs from device manger and restart the unit and check,
Posted on Jul 03, 2009
bob_computer
  • 3153 Answers
SOURCE: usb ports not working
Check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Also check HP's support section on the web for any updated drivers especially for your laptops motherboard / bios
Any exclamation marks by hardware need fixing before you investigate any further
Once you have done that try some of the common fixes below.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
Posted on Aug 30, 2009
Hp pavilion dv2000 sound driver
you can download the driver from this site
http://go4download.com/hp-pavilion-dv5-driver
Jan 09, 2011 | Computers & Internet
How do i down load music frm laptop 2 usb help plz in plain english
Put your USB Pen into the USB Port. Go to the folder where you keep the music file on your computer, right click on the file and highlight 'send to'. This should then give you a choice of options, one of which will be 'removable disc' This is your 'usb pen drive'. Select this option and the file will copy over, you should get a box comes up telling you that it is copying.
Feedback is always appreciated
JEnny
Sep 14, 2009 | HP Pavilion dv9000z Notebook
Reformatting an HP Pavilion DV2000
when you put in the windows installation disc and restart your computer you will get a screen where you have the option to delete and reformat any existing disc partitions, choose delete current partition and reformat in NTFS and then you can install windows on newly formatted drive
May 10, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a hp pavilion dv2000 machine currently it is loaded with windows 6.0 OS now i want to install ubuntu but i am not able to enter into bios mode to change the boot drive.
To enter setup, you usually have to press a specific key as the computer boot, on the initial POST screen. Common keys are Del, F2, F10, F12.
May 02, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Thinking about purchasing a HP loading dock HP DV2000(ES631AA)
Compatibility document.write(neg_specification_newline('HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Note: When using a notebook that requires the included Expansion Accessory Adapter, the following functions will not be supported on the HP Notebook QuickDock: VGA port functionality, stereo microphone (only mono is supported) and power button (must use the notebook power button).')); HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Apr 18, 2009 | HP Computers & Internet
My monitor is not working hp pavilion dv2000
hook a vga monitor to the external port on the lappy use function keys to see if it is putting out a video signal if not mobo / video card may be bad if it is cable / lcd maybe bad or could be a virus
Oct 24, 2008 | HP 417035-001 - HP Pavilion dv2000 Series...
Usb 2.0 error
did you connect directly to your laptop or you connected via external USB Hub?? Your notebook model should support USB 2.0 ...so it should not face the problem you post..unless you're not connecting it directly.
takecare.
May 05, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP GbE2c Layer2/3 Ethernet Blade Switch for c-Class BladeSystem - Switch - 16 ports - EN, Fast EN, G... Logo
180 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
