Question about Canon PIXMA MP520 InkJet Printer
LCD screen -White . Doesnt show instruction when using function
Lcd not working
  • 126 Answers
You LCD is not making proper contact with the camera board that the flex cable plugs into or you have a bad flex connector. A LCD has 2 part, the actual image and the backlight. All you are getting is the backlight with no image. You camera will have to be repaired to see if reinserting the cable into the flex connector will solve the problem.
Posted on Jul 02, 2009
  • 36 Answers
Change the flat ribbon cable
sold here
http://www.chargeconverter.com/shop/connector.htm?conndev.htm
my experience guide:
https://sites.google.com/site/bricolagesetc/imprimante-pixma-520
Posted on May 24, 2010
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
White screen on hp w2007 LCD monitor.
Troubleshoot an HP LCD Monitor
HP makes a number of liquid crystal display, or LCD, monitors.
LCD monitors create an image by passing light through a liquid crystal solution that either blocks the light or allows it to pass through to a color filter.
LCD monitors are ideal for use with a computer as they present an excellent still image and cannot suffer pixel burn-in like other flat-screen display technologies.
Even quality monitors run into the occasional problem and need some basic troubleshooting before sending them in for service.
Check the power cord to make sure that it is plugged in securely to both the monitor and the outlet. If you are using a surge protector, remove it and plug the power cord directly into an outlet that you know is working.
Detach and reattach both ends of the cable running from your computer to your monitor.
If your HP LCD monitor has more than one connector, use the other one to make sure that the connector isn't the issue.
Remove any switch or extension cable that may be present between the computer and the monitor.
Restart your computer. A fresh start will correct many software issues.
Check the documentation of your video card to make sure that it supports HDCP, or High Bandwidth Digital Content Protection, since the screen may be blank when you are trying to watch high-definition content through a video card that doesn't support it.
Some older HP LCD monitors also do not support HDCP, so check your monitor documentation as well.
Go to your video card manufacturer's website and install the latest drivers for your video card. Instructions for installing the drivers will vary by manufacturer, but they should be listed with the driver software.
Change your resolution to a preset video mode to make sure that you aren't trying to operate the monitor in an unsupported resolution.
Different models of HP LCD monitors support different preset video modes.
All of the preset video modes for your monitor are listed in your monitor's manual.
Resolutions of 1024 x 768 and lower are supported by almost all HP LCD monitors.
Press the "Auto/Select" button on the front of the HP LCD monitor to correct any images that are dark or blurry.
If this does not correct the image, press the "Menu" button on the front of the monitor to bring up the on-screen display menu, where you can use the "+" and "-" buttons to scroll through the options and "Enter" to select the option that you want to change.
Adjust the brightness and contrast as needed by selecting them and using the "+" and "-" keys. Press the "Menu" button to exit the menu.
Press the "Menu" button to enter the menu, scroll to "Image Control" and press "Enter."
From here you can choose the "Auto-Adjustment" option and the HP LCD monitor will automatically adjust the horizontal and vertical positioning to center the screen.
The ability to adjust these settings is available only if you are using VGA inputs.
Contact your retailer or manufacturer for any additional troubleshooting steps for your particular model of HP LCD monitor.
If your monitor still has issues, you may need to send it in to be serviced.
HP Support
http://welcome.hp.com/country/us/en/support.html
Fix a White Screen on an LCD Monitor
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty.
You will need to troubleshoot these possibilities to determine which problem you have.
If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it.
Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot.
If your computer display does not show on the functioning LCD screen, try rebooting your computer.
If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance.
If your computer display shows normally on the working LCD screen, proceed to Step 2.
Unplug the LCD monitor with the white screen.
Disassemble the rear panel of the monitor with the small screwdriver.
Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor.
Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen.
See the References section for photos of the video cable for assistance.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Unplug the cable, checking for any debris or blockage.
Reconnect the cable firmly.
Reassemble the LCD screen. Plug it in and connect it to your computer.
If the screen is still white, you have a defective LCD screen.
You will need to replace it or take it to a professional repair service for assistance.
Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1).
After that you connect another working screen and test video.
For this purpose I'm using one of my test LCD screens.
My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image.
After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
Aug 04, 2013 | HP W2007 20.1 Widescreen Monitor
A friends laptop is only showing a white screen
Step 1:
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
My pc desktop is showing a white screen when its on what should i do?
Is it an LCD monitor ?
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
My pc is showing a white screen when iys on
My Sony Ericsson W580 just shows a white sceen an i cant go to anything else
More than likely you will need to replace the display screen but before you do take the screen out and reseat the LCD connector. This will sometimes fix a white screen.
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
Mar 22, 2009 | Sony Ericsson w580i Cellular Phone
My w810i phone shows up a white screen..my phone is 1.3 yrs old...i am unable to do anything..please help me...in this in concern..thanks in advance...!!
If your computer recognizes your phone when you plug it in, you may have a problem with the lcd screen.
When my Sony W810i had the white screen problem, I was about to buy a new phone when I found out about the Sony Ericsson Update Service (SEUS). I used it to fix the firmware inside my phone, even though the phone seemed dead and my computer wouldn't recognize it. You can download the SEUS from Sony's website here:
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w810i?lc=en&cc=us
Mar 15, 2009 | Sony Ericsson Walkman W810i Cellular Phone
PLZ HELP SIDEKICK 3 SCREEN WENT RED AN GREEN
reylakers-
You can try and reset the flex cable on the lcd.
follow these instructions.
Fix Sidekick White LCD Screen
If that doesnt work then a new lcd screen unit will.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
MY N1 LCD GONE WHITE
you have a damaged LCD screen ..
goo & get it fiiiiixed. yourwelcome .
Jan 24, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Canon PIXMA MP520 InkJet Printer Logo
874 people viewed this question
old marine
old marine
