Question about HP Officejet 7130 All-In-One InkJet Printer
Computer does not recognize Hp 7130 printer
The software is properly loaded, the drivers updated but my computer does not show the printer as connected. I have tried all advice provided by HP website abd other sources but to no avail. What more can I do?
  • 112 Answers
Http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Posted on Jan 19, 2010
Yes I installed the driver for the printer and it shows, but the computer still does not recognized the printer.
You say the driver "shows"....what exactly do you mean by that? Normally if the driver loads properly and you see printer, then the computer HAS recognized the printer. What you may need to do is select the printer as the default printer in order to use it. Or am I misunderstanding your statement?
Nov 23, 2015 | Office Equipment & Supplies
Sound card driver not recognized
Go to the website below.
If you know your product name/number of your computer you can search for the driver.
You also have the option of letting HP automatically detect, or
you can work through the selection process at the bottom of the page.
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
With an updated driver the computer should recognize your sound card if properly connected. If you have further problems after updating your driver you can also find assistance here:
http://welcome.hp.com/country/us/en/support.html?pageDisplay=support
Trust this is helpful. Please vote. :)
Dec 21, 2010 | HP Computers & Internet
Printer wont work
try plugging it off . and then try another cable to connect the computer. Is the computer recognizing the printer . and look for updates on hp.com for the printer drivers.
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
I can not scan using my HP color laserjet 2840
Hello, wmpinc1
Sometimes what happens is that the software installed on your computer, relating to the printer will become sort of confused. Re-install the software after a quick un-install of the same software. You can get the software from either a disc or from the Web Site of the scanners manufacturer.
Sometimes updating the USB Drivers will be needed. Do that by visiting the maker of your computer and search for Drivers and Updates on their Web Site, look for 2.0 USB drivers class, download that package to your desktop. The driver might be in the form of a Zip FIle. In that case, unzip the files using standard WinZip program or use software provided by computer, to a folder called cab. The driver program might show preference were it wants to unzip to. If so, let it do its thing. Then afterwards find the folder (cab or other folder) run USB driver by clicking install exe file. Note that all periperials need to be unconnected from all USB ports ( the port the laser printer connects to the computer at ) before updating USB drivers. So check cables for solid reconnection after installing drivers.
Its important to recognize the version of the operating system you own. You'll find that information by clicking on Start Menu > Settings > Control Panel > System.
After doing this update, an reconnecting the power and USB cables. Check the operation of the scanner table itself.
Verify that there is nothing wrong with the light bulb belonging to the scanner. To do this have the cover up of the scanner table (if there is a cover) and press scan button, the program should initialized on your desktop, the the light should turn on (look for a light turnning on) and after a few seconds (or more) somethiing should start moving indicating the scanner is working properly. If you think the scanner is defective contact HP.
Good luck, jasahasch
Aug 13, 2009 | HP LaserJet 2840 All-In-One Printer
Computer won't recongnize printer
The problem is with the device driver. Every piece of hardware has a corresponding software program called a device driver to let Vista/XP know it is there and what it does and how to do it. If a disc came with your printer then that is what loads the device driver. However, with USB devices you must load the driver with the USB cable unplugged from the printer. Then once the driver loads then plug in the printer...nobody knows exactly why but that is with all USB devices. So unplug and load the disc, then plug and see if it works. You may have to reboot..if that does not work let me know as they are a couple of ways to get it to working. Good luck and keep me updated. Pls rate this solution.
Apr 05, 2009 | HP PSC 1210 All-In-One InkJet Printer
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Printer copies come out blank
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | HP Officejet 7130 All-In-One InkJet...
LightScribe installed properly, but not seen by other software.
Software problem with NERO and Surething LightScribe. Didn't see the "LightScribe' option in thier software.
Droppix Lightscribe software worked fine.
Dec 28, 2008 | HP LightScribe dvd640i (DVD640I)...
HP 7130 WILL NOT PRINT BLACK
hp nokia ce0168 code:059W7P3 imei 1:357802/06/817772/2 imei 2:357802/06/817773/0
Dec 26, 2017 | HP Officejet 7130 All-In-One InkJet...
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Officejet 7130 All-In-One InkJet Printer Logo
112 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
