I have a thermaltake dh 102 touch screen case and the 7''lcd monitor will not respond i was using the imon manager and i pressed lcd reset and the screen went off can you help
    Problem Solver:
  • 5 Answers
Put the power off, wait 1 minute and try again.
Posted on Jul 02, 2009
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 30, 2017 | Televison & Video
I have thermaltake dh 202, gigabyte motherboard GIGABYTE GA-890GPA-UD3H completely new built system (not finished yet, havent installed sata hard drives and windows too) and i have two little problems. ...
Usually on the bottom right side of the motherboard there are the front panel connections, check with the manual thet they're connected properly. If they are, you're mb might be broken. contact your vendor
Oct 02, 2010 | Thermaltake DH 202 VJ80011N2Z Digital Home...
How to connect the card reader to motherboard
its basically half a internal usb plug. just match it up with a different internal usb connector so you line up the right wires.
Jan 24, 2010 | Thermaltake DH 202 VJ80011N2Z Digital Home...
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
I am using a Dell Lattitude D830. I added another monitor (Dell) for home use. First time I hooked it up, it worked fine. Today, I took the laptop with me, so unplugged the monitor. Now, I cannot get the...
Have you tried the "function key + F8 key" since that usually is the key combo you press to switch between built in LCD and external monitor on a Dell laptop.
Worst case scenario would probably be some type of driver setting or resolution setting might be to high. and in that case you can try system restore (with the monitor connected of course) to the day it was working and see if the setting go back to that time...
This solution is the easiest one to try since you can always undo the restore operation if it doesn’t resolve the issue
Nov 30, 2008 | Dell E176FP 17" LCD Monitor
Helpme please
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Philips 150S4FB 15" LCD Monitor
Samsung lcd tv
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
Touch screen not responding.
Any chance you are using screen protectors and that the edge may have shifted under the case? If yes you have what I call a wedgie and it's causing a phantom tap in a non-accessible area. Remove screen protector.
Any chance there is some dirt/detritus wedged just under the edge of the case pressing on the digitizer? Fold the corner of a piece of copier paper to form a scoop and go around the perimeter of the screen no more than 2.5mm under the case to dislodge (not push in) anything stuck there. This method solved this same problem on my HTC phone
Nov 04, 2007 | Computers & Internet
How to adjust sensitivity on ELO Touch Screen monitors
you probably have a capacitive screen, it only responds to finger press. You need a resistive screen to be able to respond to finger, nail, or pen press.
Aug 28, 2007 | Elo 15" Touch Monitor
Touch screen
You may have dust accumulation around the edges of your touchscreen, between the screen and the case. Try using a can of compressed air. Gently press down on the edges of the touchscreen to expose the gap between the screen and the case, and shoot the air in there. This worked for me when my Treo 600 touchscreen stopped responding.
May 23, 2007 | Palm Treo 600 Handheld
Computers & Internet Logo
89 people viewed this question
Alun Cox
David Payne
David Payne
