Refrigerators Logo
T
Tom Larson Posted on Aug 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Removal of icemaker fro Amana Model AFI2538AEB4 refrigerator.
I need information showing how to remove an icemaker from this model.
Thomas Beaver
Level 3:
  • Refrigerators Master 2,119 Answers
  • Posted on Aug 30, 2014
Thomas Beaver
Level 3:
Answers
2119
Questions
0
Helped
752096
Points
6319
3answers
What year is my Amana refrigerator, Model # ASD2522WRB06?
I'd like to know how you determine the age based on the info inside my Amana. I double checked the numbers.
Model AFI2538AEB4
Serial KY2886165
2answers
Amana model aqbb1921dew
You will have to look in the freezer section and see if there are holes in the left side wall to mount the icemaker and also if you look at the left rear of freezer section to see if there is a spot for the harness to plug in. Also look on the model serial tag inside unit to see if they listthe part number to add on icemaker kit.
Amana model tg21vl stops making ice
pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
Maytag mfd2560hes how to replace defrost thermostat
The service manual 16025629 is here: (7.46 mb)
http://appliancedigest.com/index.php?/files/file/498-16025629-maytag-amana-bottom-mount-refrigerator-service-manual
You will have to register to download the manual.
Freezer Back Panel
NOTE: Freezer compartment should now be empty and
walls should be clear of anything that will
obstruct removal of back panel.
1. Loosen screws that mount icemaker to freezer
compartment walls.
2. Pull icemaker gently away from wall of compartment.
As you do so, work fill cup free of fill tube. Unplug
icemaker electrical connector and remove icemaker
from unit.
3. (Pull out Drawer only) Loosen and remove screws
that hold 2 basket glides in place at left and right
sides of compartment.
4. If unit has no icemaker pry with flatblade icemaker
connection cover. Remove cover.
5. Remove hex head screws that hold back panel and
remove panel.
6. Squeeze tabs on ice maker plug to release it from
back panel
Defrost Terminator (Thermostat)
1. Terminator is fastened to evaporator tubing with a
spring clip.
2. Snap terminator off tubing and cut wires to terminator.
3. Remove terminator from unit.
That is word for word.
See parts list diagram here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=28480593#d28480593
This may help with screws but the defrost thermostat is item 32 and not shown on the diagram. Once you hav ethe access panel off loof fok the thermostat. It will have 2 wires and tough metal clip on it.
Thanks for choosing FixYa,
Kelly
1helpful
2answers
Water leak on floor
Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
2helpful
We are in Australia and have had an Amana XRSS287BW fridge freezer with ice maker for 5 years. The freezer is icing up near the ice maker, the condensor is not icing up. It appears to ice up and the fan...
they do not repair icemakers for the simple fact it is cheaper to just buy a new unit aka icemaker in fact the icemaker when the repairman buys it costs him between 47-90 dollars at which for him to disconnect the three bolts and reinstall the icemaker the charge usually starting around 189.00 first thing to do would be to look at the tube where the water is going into the icemaker and observe if you have a leak from the tube the next step would be to inspect the icemaker for cracks in the ice making tray if this is also ok has your repairman checked the t-stat this is a small two wire round disc like object located behind the back panel this is what regulates your temptreture and turns the heater on when your freezer gets to cold another thing to check would the drain tube that goes from the bottom tray under the condensor sometimes this also gets blocked with ice.In turn when it does get blocked the ice just builds up the t-stat is located as part number 3 on this diagram from this link http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00014?blt=06&prst=&shdMod= lastly if your fan is not spinning at the addequate speed that it is supposed to be spinning at then the amount of cold air would not be leaving your freezer to go into your fridgerator and when the heater kicked on the water that melted off the condensor coils would build up also as ice if your repairman is saying its the icemaker visually inspect the icemaker yourself here is a link also showing how to remove your icemaker http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-XRSS287BW0/1268/0165000/M0610184/00008?blt=06&prst=&shdMod= please message me back with your finds after you have visually inspected for yourself. i hope this opinion has helped in your appliance situation please remember to rank how this opinion has helped in your appliance situation and i await your reply
Thanks
Rick
SCD25TW Amana 1998
the fuse for the i/m is actually in the wiring harness that plugs into the icemaker. if the model is correct the icemaker goes across the back of the freezer. when you installed the icemaker on one of the wires (i think red wire) there is a black "pill" looking thing. this is the fuse.
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
