Question about Kyocera FS-3900DN Laser Printer
Keeps "jamming" although no paper is stuck.. - Kyocera FS-3900DN Laser Printer
  • 2 more comments
  • tom_brooks Jul 02, 2009
    It does pick up the paper still, you just have to keep switching it off and on to print anything. This is happening to quite a few of these around the company!
    Problem Solver:
  • 14 Answers
You have to upgrade the firmware
Posted on Jul 13, 2009
  • 60 Answers
Could be a hundred reasons, most likely is the rollers are worn try rubbing the rollers with a scouring pad which will give them a bit more friction to grab the paper with, this is only a temperary fix though!
Posted on Jul 02, 2009
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Printer keeps saying i got a jammed paper there is no jammed paper
There are many places in a printer where a small piece of paper can get stuck. It's not always a sheet of paper. Open all the access panels and check the roller track for pieces of paper. If it is clear, unplug the printer for a few seconds and the plug it back in. This should clear the problem if it was in error. Also check the paper feed for too many sheets stuck together jamming the feed. Before loading paper always "fan" the paper first to avoid sheets being stuck together.
Apr 14, 2011 | Canon Office Equipment & Supplies
The roller on the feed tray keeps feeding through eventhough there is no paper there and the panel keeps saying there is a jam
If it doesn't do this with paper in the tray, it's a stuck paper present sensor flag.
If the machine thinks there's paper there, it tries to feed. Since paper doesn't make it to the timing sensor, it shows a jam.
Check for a stuck flag above where the leading edge of paper would be with the cassette inserted.
Mar 04, 2011 | Xerox Office Equipment & Supplies
Paper jam error message..no jam
Hello There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
My ip100 printer keeps displaying paper jam when there is no paper in the printer
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 10, 2009 | Canon iP100 Portable Printer
Paper keeps getting stuck
see if the paper sensor are jam or if the machine have paper jam.
Jun 18, 2009 | Canon Office Equipment & Supplies
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
Kyocera FS-3900DN Laser Printer Logo
210 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
