Question about Palm TX Handheld
I can not get my sreen to calibrate
It does not find centre of target
    Genius:
  • 1,847 Answers
These link should help you..
http://kb.palm.com/wps/portal/kb/common/article/24443_en.html
Also check this video
http://www.ehow.com/video_2145290_calibrate-touch-screen-pda.html
Thanks
Kindly rate the answer
Kevin
Posted on Jul 02, 2009
I have a icoustic mp3 player which i downloaded music to but i deleted the music
The blue screen is a screen calibration. Just touch the screen exactly in the center of the little boxes in the corners of the screen for about a second and remove your finger. Do this until it says success and you should be good to go.
Feb 09, 2013 | Coby MP828 MP3 Player
Dell latitude d820 wont fit tv sreen when duel monitors are set
Looking for Dell service Centre in chennai?get in touch with the laptop shoppe the best dell laptop service centre in chennai,the one stop solution centre for all your laptop queries and we ensure your laptop is repaired and it can smoothly within minimum downtime.
Nov 22, 2012 | Dell Latitude D600 Notebook
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
HOW CAN DO PHONE CALIBRATION?
Over the time, the touchscreen might have to recalibrate for better touch precision. If you press 1 but it activates 2 in the To calibrate Nokia 5800 touchscreen: Click the menu key > Settings > Phone > Touch Input > Touch screen calibration. There you are prompted to tap centre of target with stylus, where the 4 circles (target) at the corner animates one by one to guide user complete the touch screen calibration process.
May 05, 2010 | Nokia 5800 XpressMusic Smartphone
Calibration gets stuck in a loop
Hello.
Do a soft or hard reset (pin in back of PDA; pin in back of PDA and front silver button simultaneously).
If not, what worked for me is to take the PDA apart, if you are comfortable. There are 4 screws in the back. Remove them. With a knife, flathead screwdriver or other flat object, pry open the back. A few plastic pieces may fall out, tho. Note where they connect. Disconnect and then reconnect the power adapter. Put the plastic pieces and the back of the PDA together. The back should snap in place. Insert the 4 screws. Should work OK, again. Use this method if the adapter is not charging very well and the soft / hard reset doesn't work. I've had to perform this many times. Good luck.
Oct 28, 2009 | Palm Tungsten E2 (Multilingual) Handheld
I found message ' tap the centre of the target repeat as the target moves ' in samsung d980 how can i solve this problem thanks
Hello!
Dont worry about it , it's just the calibration wizard.Tap the centre of the target (the cross) with the touch pen (you'll have to do it more than once befor finishing the calibration)
Oct 21, 2009 | Samsung SGH-D980 Cell Phone
When i do hard reset hx2490b screen calibration does not appear
Try using your finger to calibrate the screen at first. (If you have difficult to navigate to the alignment screen use the stylus & keyboard to feel out your way) when calibrated to an accepable degree use the stylus to calibrate the sreen, if the target doesn't respond to stylus at any specific piont use your finger. Continue this process till u get it aligned as best as possible. I suspect this problem is caused by specific points on the screen going bad.
Feb 24, 2009 | HP iPAQ HX2490 Pocket PC
No target appears on the calibration screen
I just got one of these for my 4 yo daughter and had the same problem after 2 days. GOOD NEWS IS IT IS FIXED. The problem was crumbs stuck between the edges of the screen and the frame piece around the edge of the screen. I assume this was creatintg pressure in 2 places at once, confusing the screen/software and not showing a target on the calibration screen.
I used a toothpick to remove the visible crumbs, but if you have a can of compressed air used for computer cleaning, than that might be even a better idea. It seems that screen problems were chronic back in 2004, but no so much now. I learned about this here: http://www.watercoolergames.org/archives/000028.shtml
GOOD LUCK and post back if it works as it is simple and maybe some of the other people with problems have ths same simple issue.
Dec 23, 2008 | LeapFrog LeapSter L-Max Console
Calibration
You can download and print one from Document Capture Technologies site here: http://www.docucap.com/index.php?/downloads . Scroll down to the Travelscan 464/464M section and download the TS 464 Calibration Target for letter print size paper (PDF) or TS 464 Calibration Target for A4 print size paper (PDF) page.
Oct 24, 2008 | Alestron TravelScan 464 Pass-Through...
Palm TX Handheld Logo
19 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
