Question about Yamaha CDR-HD1300 CD Recorder
Yamaha CDR1300 - Can't format new HDD
Machine had message Drive check. On advice from technician we bought new WD3200AAJB 350GB. Followed HDD Installation manual instructions. No display, niks. Then followed the install procedure in the owners manual, message Format NG. Any suggestions on how to get the HDD formatted? The machine will play back.
Leo
Kimi
  • 277 Answers
SOURCE: DVD won't play
Is this happens on every disc? The NO PLAY message appears when "The disc that this unit cannot play is loaded (from the user guide)". Maybe it's something to do with the DVD region? If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Posted on Dec 19, 2005
  • 214 Answers
SOURCE: my Yamaha S1700 DVD player does not play HD dvd's.
I just looked at spec's and they don't mention HD Are you sure it is supposed to play HD DVD's?
Posted on Nov 17, 2008
  • 120 Answers
SOURCE: Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Posted on Jan 02, 2009
  • 5603 Answers
SOURCE: I have PSR-i425 Keyboard from Yamaha. I stored the
The BUP is an archiving format proprietary to the Yamaha apparently containg styles as well as note data and conversion is really not easy.
If you can get the instrument itself to spill out MIDI and use a MIDI interface and software to capture it on the PC is the best plan.
Once it is in SMF format you can play it on the PC.
Posted on Jun 25, 2010
dunnbiker
  • 8546 Answers
SOURCE: We own a yamaha receiver
I appreciate your following the manual first and thorough elimination of all the obvious stuff.
Your speaker settings should be set according to whether they can handle real bass or not; and impedance settings should be set to agree with the load you're presenting to the amps.
Just curious, what speakers are we using and are they comfortably high in impedance (no 4-ohm ones)? Be specific.
But you say it gives no warnings so it's not likely to be speakers.
Just the same, if you can count on it to fail in a reasonable time try this: disconnect all the speakers and turn it on. Go away for awhile and when you come back see if it has failed. If it HAS failed the speakers are a non-issue and something else is afoot.
Try this: turn it off with the remote. Does it act exactly like when it fails? Perhaps there is another
Infrared Remote, garage door opener, security system or other source nearby and the RX-V665 is reacting to it. Cover the I/R sensor on the front panel with something opaque and run that way for awhile. (see page 9)
Posted on Jan 05, 2011
SYSTEM RECOVERY AFTER REPLACING HARD DRIVE
The best solution I could find was:
Boot with a Win 7 disc, and choose Repair Your Computer. Then use Startup Repair option.
bootrec /fixboot If you end up at a command prompt from the repair option.
Oct 07, 2012 | Computers & Internet
How do I get into it and how do I clear all storage. this was bought atestate sale with out manuel
assuming windows OS:
navigate to computer manager/ disk manager
right click on the drive and select format
all the data on the drive will be cleared
Jan 30, 2010 | SimpleTech 350GB USB2.0 7200 RPM External...
Cannot start. The correct hard disc was not found
those would have been my suggestions when you did the double beep did you rebuild file system and rebuild database, if so then you prolly need a new HDD but they are cheap at tigerdirect.com and any laptop sata drive will work. just dont think of it replacing the HDD think of it as upgrading to a 250gb HDD or 350gb HDD i think they are only $50 or so but you get so mutch more HDD space
Sep 19, 2009 | Sony Playstation 3 (PS3) Console
Not enough disk space to copy
Scan the drive due to possibly virus managing your disk drive. Virus can easily access through USB hard drives. If not solve the problem, so its better to format.
Mar 12, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
YAMAHA CDR HD 1500
Go to HDD Utility -and then HDD Format
To do that click on MENU, then turn the Multi-Jog up to HDD Utility
Press once on MultiJog to select HDD Utility, and then turn the Multi-Jog to HDD Format.
Press once on MultiJog to select HDD Format
Then Click on the small "Complete" Button
Nov 23, 2008 | Yamaha CDRHD1500 CD Player
ST3250824AS Drive unreadable
to recover ur data, try using a SATA to USB cable.. it will work as a flashdrive.. then format ur HDD again after getting the data u want.
Sep 15, 2008 | Seagate (ST3250824AS) 250 GB Hard Drive
No hdd found...
Hi.
Most new hard drives are not partitioned nor formatted and therefore are not ready for use when first bought. They have to be initialized/prepared for whatever device they will be attached to. Formatting may be FAT, FAT32, NTFS and others.
This could be done using a PC where the hard drive (HD) could be initially/temporarily installed as a secondary master/slave and use the Operating System to partition and format making it ready for use. Alternately, an external casing with USB interface may be used.
For your purpose, you need to determine in what format will your digital video player/recorder accept the new HD. This may be found in the manual. Alternately, some digital video player/recorder has this feature/option that will allow you to format newly attached to HDs.
Should the above be not sufficient, please post back with the brand and model of your digital video player/recorder.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Western Digital Caviar WD400JB Special...
HDD not recognized in XP Installation
if you are using it as a slave hard drive, you should be able to right click my computer, manage, then in next window double click storage, then disk management, then look for your drive, you can then look to see if its recognised, if not it will tell you that its not configured, and you should be able to right click on it and format it.
Jun 07, 2007 | Maxtor DiamondMax 10 300 GB Hard Drive
Yamaha CDR-HD1300 CD Recorder Logo
128 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
