Computers & Internet Logo
A
Anonymous Posted on Aug 30, 2014
Change keyboard settings
When I am typing a document and the text advances to the next line, the space bar will not advance so that I can indent. It did but I don't know how it got messed up.How do I change this back?
paulq86
Level 1:
New Friend:
  • Contributor 52 Answers
  • Posted on Sep 02, 2014
paulq86
Contributor
Level 1:
New Friend:
Answers
52
Questions
0
Helped
10166
Points
99
Use the tab key instead. That's what it is there for.
5 Related Answers
Anonymous
  • 156 Answers
  • Posted on Jun 17, 2008
SOURCE: Word 2003 When using bullets, hitting
click on the bullet first and then press tab... just don place cursor after the cullet and press tab,... you must clik the bullet or numeral first and then it gets highlighted.. then you press tab
Anonymous
  • 195 Answers
  • Posted on Nov 04, 2008
SOURCE: microsoft word
No there is no refresh button, save your files to a temporary file and reinstall Word, Or Microsoft Office, that will do the trick.
Good Luck
Tripod
RICHARDM69
Desktopsbyduck-Computers
  • 1061 Answers
  • Posted on Jan 02, 2009
SOURCE: I have an ACER Aspire
Julie, your key board is dirty.take twqo butter knives and carefully pry each key off.TAKE A DAMP CLOTHE A CLEAN AREA UNDER EACH KEY REPLACE THEM THEY POP BACK ON .be carefull you can break a key .also damp only when cleaning no water and let dry befoer key replacement THIS WILL WORK.richardm69
Anonymous
  • 51 Answers
  • Posted on May 11, 2009
SOURCE: Space bar doesn't always work and a line sometimes appears when Caps are used
The batteries may be low or if that does not work just buy a new keyboard.
Anonymous
  • 515 Answers
  • Posted on Jul 09, 2010
SOURCE: Water leak filled keyboard. Now space bar doesn't
I use hair dryer for that.
I have an Epson R1900, this problem just started, it will print a line and advance the paper while printing but prints the same image or text on the next line, paper advance issue or a timing issue?
Based on the symptoms you described, it sounds like there may be a timing issue with your Epson R1900 printer. The erratic spacing and repeated printing of the same image or text on the next line suggest that the paper advance mechanism is not functioning properly. This could be caused by a number of factors, including a worn or damaged paper feed roller, a misaligned paper feed mechanism, or a malfunctioning sensor that controls the paper advance timing.
To troubleshoot this issue, you can try the following steps:
  1. Check the paper feed roller for wear or damage. If it is worn or damaged, it may need to be replaced.
  2. Check that the paper is loaded correctly in the printer, and that it is not jammed or wrinkled.
  3. Check that the paper thickness setting in the printer driver matches the paper you are using.
  4. Clean the paper feed mechanism and paper feed roller with a soft, lint-free cloth.
  5. Reset the printer by turning it off, unplugging it from the power source, and leaving it unplugged for at least 10 minutes before plugging it back in and turning it on again.
If none of these steps resolve the issue, you may need to take your printer to a qualified technician for repair or replacement of faulty parts.
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
How do i adjust the line spacing? I am not able to single space lines on my word documents.
if you are using word simply type out whatever you want to write, select the entire text, right click to go to format and in the dialogue box select single spacing.
I want short cuts in ms word
You can use this
Ctrl + A Select all contents of the page. Ctrl + B Bold highlighted selection. Ctrl + C Copy selected text. Ctrl + E Aligns the line or selected text to the center of the screen. Ctrl + F Open find box. Ctrl + I Italic highlighted selection. Ctrl + J Aligns the selected text or line to justify the screen. Ctrl + K Insert link. Ctrl + L Aligns the line or selected text to the left of the screen.
Ctrl + M Indent the paragraph. Ctrl + P Open the print window. Ctrl + R Aligns the line or selected text to the right of the screen. Ctrl + T Create a hanging indent. Ctrl + U Underline highlighted selection. Ctrl + V Paste. Ctrl + X Cut selected text. Ctrl + Y Redo the last action performed. Ctrl + Z Undo last action. Ctrl + Shift + F Change the font. Ctrl + Shift + > Increase selected font +1pts up to 12pt and then increases font +2pts. Ctrl + ] Increase selected font +1pts. Ctrl + Shift + < Decrease selected font -1pts if 12pt or lower, if above 12 decreases font by +2pt. Ctrl + [ Decrease selected font -1pts. Ctrl + Shift + * View or hide non printing characters. Ctrl + Moves one word to the left. Ctrl + Moves one word to the right. Ctrl + Moves to the beginning of the line or paragraph. Ctrl + Moves to the end of the paragraph. Ctrl + Del Deletes word to right of cursor. Ctrl + Backspace Deletes word to left of cursor. Ctrl + End Moves the cursor to the end of the document. Ctrl + Home Moves the cursor to the beginning of the document. Ctrl + Spacebar Reset highlighted text to the default font. Ctrl + 1 Single-space lines. Ctrl + 2 Double-space lines. Ctrl + 5 1.5-line spacing. Ctrl + Alt + 1 Changes text to heading 1. Ctrl + Alt + 2 Changes text to heading 2. Ctrl + Alt + 3 Changes text to heading 3. Ctrl + F1 Open the Task Pane. F1 Open Help. Alt + Ctrl + F2 Open new document. Ctrl + F2 Display the print preview. Shift + F3 Change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word. Shift + Insert Paste. F4 Repeat the last action performed (Word 2000+) F5 Open the find, replace, and go to window in Microsoft Word. Ctrl + Shift + F6 Opens to another open Microsoft Word document. F7 Spell and grammar check selected text and/or document. Shift + F7 Runs a Thesaurus check on the word highlighted. F12 Save as. Shift + F12 Save. Ctrl + Shift + F12 Prints the document. Alt + Shift + D Insert the current date. Alt + Shift + T Insert the current time.
Hai..
if you really are asking for the parts of MS word 2003,i bet this should help and really there are more than 4 parts
1. The Title bar gives the name of the document and the program being used
2. On the right side of the Title bar are three buttons.
a. The Minimize button makes the window disappear from the screen without closing
the program. You can bring the window back by clicking on its button on the Task
bar at the bottom of the screen.
b. The Reduce/Maximize button makes the window smaller or takes it back to full size.
c. The Close button closes the document or program.
3. The Menu bar offers dropdown menus for things you do in Microsoft Word.
4. The Toolbars display icons that perform specific tasks when clicked. Often the toolbar icon performs the task without offering any options.
5. The Rulers display the tabs, indents, margins and give the user a visual guide for alignment.
a. Tabs are set on the ruler by clicking the spot on the ruler where you want to the tab to
start. Different Tab settings can be used to align text, decimals and indents.
b. Indents and margins can be set with the handles.
6. The Document display window is where the current document is visible.
7. The Scroll bars allow the user to move up and down the document in the window.
8. The Status bar shows the location of the cursor, number of pages and includes advanced toolbar options.
9. The Task bar displays buttons for Open programs or documents.
1helpful
Nakajim AE-710 Will not return to next line indents & makes noise
Check for debris below and around the carrier, put some light oil on the silver shaft that the carrier slides on (wd40 works well) DickyO
2helpful
2answers
What is CTFMon.EXE and Can It Be Removed
1) Open the Control Panel2) Double-click on Regional and Language Options (if you are in Classic View)
or Double-click on Date, Time, Language, and Regional Options in Category View
3) Click on the Languages tab, then click on Details
5) Click on the Advanced Tab
6) Finally, place a checkmark in the box "Turn off advanced text services" and Click Ok
The language bar next to the System Tray should disappear, and CTFMON.EXE will unload from memory.
If you wish to bring back the language bar, simply follow the procedure above and UNCHECK the box to turn off advanced text services.
Microsoft has more information and a Frequently Asked Questions document about CTFMON.EXE, click on the link below to review it.
Frequently Asked Questions about CTFMON.EXE
Therefore, CTFMON.EXE is not a virus or a piece of malware, but its also not a program that you NEED running, expecially if you don't use Microsoft Office XP applications.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
