I have a HP 1025nw color the black toner cartidge is very low followed directions to replace cartridge the black tone cartridge does come in to place as can be seen when the front is opened but I cant pull the cartridge out
SOURCE: cannot remove toner cartridge
There is a manual removal option. Open the front cover. Then the top. Remove the drum. Close the front cover. (leave the top open). Move the toner housing unit so the required toner is accessable from the back. Remove.
Replace drum. Restart printer. The housing unit shoud rotate the empty spot to the front so you can insert the new toner.
Good luck.
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
SOURCE: HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
SOURCE: Error message coming up: The HP LaserJet 1020 has
send your printer for service. seems like, one or two sensors are malfunctioning.
SOURCE: canoon 1p2600 wont print only in black when the
The printer need both cartridges inside it to printing.Put old color cartridge, new black and press and hold the resume button for 5 seconds.
Yes, plastic cartidge holder is provided to you to store HP 337 (black inkjet print cartridge) as you remove it to install a new HP 338 ( Photo Cartidge).
Remember, below combination of Cartidges for used for specific purposes:
Black and color cartidge for general Printing of Documents.
Black, Color, Photo Cartidge to Print Photos.
Color cartidge , photo Cartidge and gray cartidge is specially used when you to print copies of photos with great quality.
I hope that this should resolve the issue for you.
You can mail me at [email protected] for further assistance, I'll be glad to help you.
Bye
