We have a grapghtec Scanner which we use to scan dwgs A1 A2 etc.Software is "Scanning ARP SP" when scanned the file sizes are huge ie examples 1.03MG & 600MG we need to reduce these file sizes to say 200/300MG. How can we do this. We would like to save as TIFF or PDF is this practical. Neil
    President:
  • 942 Answers
Hi, you can not reduce the size, because it is only legal, letter, and folio, or other bond paper size, you can save that in PDF format to drag your scan item in the pdf icon
Regards
PCmania
Posted on Jul 02, 2009
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
Text being scanned does not produce a clear print to our cannon ip18oo printer
alot of the time if you scan something it will streach the image because of the scanner resolution. check you setting on the printer. you might need to change the settings to stop it from doing that to make he image more clear. if that doesn't work than also some printers are just like that when you scan something. it will also make one page turn into two pages. that may just be the way the printer is.
Aug 13, 2008 | HP Office Equipment & Supplies
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
How can i save a scanned file as an image on my desktop? for example when i finish the scanning by pressing the scan button it appears "an unexpected error ....etc" so i cannot complete the...
You have to associate that button, with a storage directory, you must set up the preferences, and tell the scanner where to save the scanned file.
Jun 10, 2010 | Agfa SnapScan 1212u Flatbed Scanner
Recognizing hardware on a Mac OS X Tiger
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG"
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Aug 06, 2008 | Epson Perfection V100 Flatbed Scanner
HELLO
Use the following steps to scan with the Epson Scan utility:
1. Open Epson Scan by going into START, PROGRAMS, and EPSON SCAN.
-LOCATION defaults to MY DOCUMENTS. Click BROWSE if you wish to change this.
PICTURES will be "IMG001.JPG". More settings for file format are found under OPTIONS.
Jun 22, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson
I know the error is on the printer but it may still let you scan.
Jun 06, 2008 | Epson CX8400 All-In-One InkJet Printer
Scanning problem!
First Scan only a single page and note file size. Now scan 3 or 4 pages ad check the file size. If it is more, then the scanner is clubbing/collating all the images into a single file. Check your software settings and disable this feature if you want individual files.
S. Mohan
Mar 12, 2008 | Fujitsu fi-5750C Flatbed Scanner
Brother 3240c Error A1 ,A2 and 82
Not sure what 82 code is but A2 and A1 have to do with size of paper possible original to long for size of paper in cassette
Mar 28, 2017 | Brother MFC-3240C All-In-One InkJet...
Scanner to Pc File Size and Volume Problems
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Jan 18, 2007 | Canon DR-9080C Path-Through Scanner
k24674
jasbo
jasbo
