Will turn on and let you set the control panel, but freezes when you push start. After that it does not matter which buttom you psh it beeps three times. Drain line is not blocked.
Pump jammed or bad. Tilt machine forward. Remove back panel drain pump is located when facing front of machine on back right hand side. Unplug power wire,3 5/16 screws hold pump in place, remove, unclamp both hoses and remove pump. Remove any objects, check and make sure housing isn't cracked as coins sometimes make it into pump and can crack housing. If objects found and remove, reinstall pump, it should work. WHEN REMOVING PUMP PLACE BUCKET UNDERNEATH TO CATCH ANY WATER
SOURCE: Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
SOURCE: kenmore elite oasis f-1 error code about every 4th washing
main control board need replacing
SOURCE: Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
SOURCE: my kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
SOURCE: Kenmore Elite Oasis HE top loader has LD error code
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5
minutes to pump out the water to a point where the pressure switch resets. To
solve this problem make sure that the drain filter pump assembly located inside
the bottom front panel is clean and after cleaning if the error returns then
the pressure switch needs to be tested and if bad then it needs replacement.
Please get back to me if you have any other questions.
Kevin
