Question about Canon BubbleJet i9950 InkJet Photo Printer
I have Canon I9950 Printer with faulty Logic board QM2-1272
I try the find out some parts what is they are which is part package has Marked D6F 5 Pin SOT it looks like to me optocoupler but I am not sure. Board number QM2-1272, on the board silk screen printed DA401 ~ DA410 which is used 10 PCS same part. located below the connectors JCR3, JCR2, JCR1 Left side of the logic board, on my board several of them smoked I wonder any one can help me about verify those parts.
Thank You all in Advance
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
Hi I recently had an error on my printer 5 blinks of the error light. I established from the internet that it was a print head failure. So I purchased a QY6-0075 to replace the original QY6-0067 print head...
Oh dear you have suffered what is probably the worst that can happen to this machine. When your original print head failed it took out the logic board with it. They should have been replaced as a pair at the same time. thats what we (canon engineers) do. Fortunately the logic board is not to expensive . The logic board part number is QM3-2738.
Good luck.
PS. I take no responsibilty if the logic board does not cure as although the print head works in another machine it may not in this one. Srri
Aug 17, 2011 | Canon Pixma iP4500 InkJet Printer
My Canon Pixma MP990 stopped working. First the wi-fi light went out, and the LCD screen went dead. Then the blue light stopped coming on at all, and all I have when I plug in the printer is the yellow...
It sounds like you have an electronic problem, it is most likely a faulty scanner or logic board. although a faulty print head can take out a logic.check that there is no burning smell or damage evident on the underside of the print head before trying a logic.
the machine will require disassembly and parts replacement.
Aug 16, 2011 | Canon Pixma MP990 InkJet Printer
Canon i9950 printer problem error 5c00
According to the Service Manual Error Code List these are the two possible candidates to cause this failure:
- Purge unit (Part-No. QM2-1307)
- Logic board ***’y (Part-No. QM2-1272/QM2-1273)
which means, this device has to go to the service.
(Or to bereplaced)
Best Regards
cominarosa
Mar 04, 2010 | Office Equipment & Supplies
Canon i9950, Operator error,5 amber blinks
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 02, 2010 | Canon i9950 InkJet Printer
Canon mp460 not recognising replaced ink cartridge and cannot get rid of alarm code
hi guys,
BTW, did you refill the cartridge?. First, try to press START button (Black or Colour). Perform this procedure for each cartridge. If the problem still persist there some possibilities: cartridge error, carriage part or logic board is faulty. Then you need to replace faulty part.
Regards
Source:
Canon Inkjet Forum
Dec 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon i9950: Full waste ink absorber
Dhedik maybe this action can solved your problem Reset Waste Ink Counter printer Canon i9950 :  1. power off  Printer
2. Push and hold resume  button and push power button
3. Hold  Power button and release Resume  button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and  stop.
6. When green light on, push resume button 4 x
7. Push  Power button and printer will off, if that isn't off, push power butto again until print off position.
ok good try, don't forger to vote me, Fixya
Apr 02, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
Oct 10, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Canon BubbleJet i9950 InkJet Photo Printer Logo
204 people viewed this question
old marine
old marine
